hello
if you intrested in asking anything about cars good to give tilbrook auto and dyno a call mark will be able to help you ouy or as me i found out for ya!!!
i admire you got a R34 tho!! he he he he
I assume the housing is still the Xenon but they butchered the wiring and fitted Halogen globes?
Yeah it has the xenon housing but it actually looks neat when they fitted the halogen globes. There is a spare plug there that is taped up. I havent got the origional parts but will be picking them up during the week.
I mean i don think its going to be as easy as fitting the origional ignighter and globe unfortunatly.
I hope you are picking up the entire headlight assembly along with any power gear required. Once the original unit has been converted to run halogens, it's a irreversible process from what I understand.
I had mine swapped back after compliance and it was a pretty big job - front bar needs to be taken off. Takes about an hour all up if you have all the right tools and know what you're doing.
and make sure you well seal the headlight once you're done.
Also, glue the parker light panel and globe housing thats held by 3 pieces as they tend to come off easily. Happened to me and I had to open the whole headlight just to fix that bit.
and make sure you seal the headlight very well. Yesterday i washed the car and the inside is completely fogged up because I didn't seal it after pulling it apart! Now I have to re-open it, clean it and seal it good.
oh and finally, don't overcook the headlight in the oven when melting the silicon sealing as everything tends to melt, especially the top headlight clips that are bolted onto the chassis.
how is it that mine, among other R34s have Xenon lights on the road?
There is a way to fit halogens to an R34 headlight without butchering the Xenon bits and pieces. Once compliance is completed the Xenon goodness can be refitted (by you or your workshop).
This however is about an hours? work and not all workshops know how or what theyre doing so destroying a perfectly good headlight is usually what happens.
I don't know what the issue is. Mine was converted to halogen and I converted them back.
If you're lucky, all they do to run the halogen's is to insert a metal plate in to the seat for the burners. This allows them to fit the halogen globe in there securely. All you do is remove the plate and the burners slot straight in.
Wiring up the ballast might be your issue, all I did was cut and join, then tape up with electrical tape and shrink wrap over it. Never had a problem.
If you're in Sydney and want help in fitting it, PM me and I'll be happy to give you a hand.
Ed you may need a few more bits.
The issue is that some are easy to convert back. Some have only had one control unit removed, some (majority of QLD complied cars) have the base of the lamp cut & the second unit removed from inside the assembly not that easy to reinstall. Some I have seen have had the entire globe base removed. And finally some have a flat insert that if the compliance company doing their job, they should have bent the reflectors in.
Additionally, you’re only playing with about 400 volts so make sure it’s well insulated.
:P
I only drove the car at night for the forst time last night and the head light aim is absoloutly FKD!!$@#@$ I tried to adjust the aim but even on the lowest settings the aim is still way to high. Im guessing you pretty much have to remove the headlight to see if its worth attemption the conversion...
Ok this is the latest with the headlights on this car. I think i possibly have the most dody halogen conversion ever. I could not aim the head lights and they were weak as piss to the point it was dangerous to drive at night so i went to remove and inspect the globes. As i removed the globe i noticed like a ceramic ring had been put between the H1 globe and the back of the fitting to stop the globe falling through into the headlight and as i removed the retainer that was just grabbing one small corner of the globe the cermaic ring on both sides crumbled into bits!@@!@#@#!@@ Now also the guy that imported the car isnt going to let me take the parts that removed so im a bit pissed.
Whats the best option to temporarily hold my H1 globes in and what are the options for converting to Xenon? Is it economical to buy a complete xenon equiped headlight unit for the R34?
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
