Hey guys, how many of you will be interested in participating with an MSC Performance Dyno Day? I will be speaking with Steve and Joe from msc about this. I want to see if there is alot of interest.
where is MSC located?
Paying members only.
workshop is TBA, but it'll be dirty cheap, probably around the $30 mark.
Member events will usually includes a BBQ among other things too :)
Remember there was a dyno day also in Nov last year also.
I've found it hard to get numbers to Dyno Days on the past 3-4 that ive organised. Dunno why :dry:
Member events will usually includes a BBQ among other things too ;)
I've found it hard to get numbers to Dyno Days on the past 3-4 that ive organised. Dunno why :P
Well personally I couldn't be arsed unless it came with a decent tune. I don't know, to me it seems pointless? Maybe I'm missing something.. The BBQ sounds fairly enticing tho ;D
I agree, I can rev the ring out of it just as much and enjoy it more :P Well till it goes bang anyway ;)
HEy
A dyno day at MSC would be great - im there almost every week - Steve and Joe and top blokes and really know what they are doing - Ive had my car on there dyno there before.
LTHLRB do I know you? Im Kim with the White SII R33 - Steve n Joe are customers of mine, I work for Wurth australia.
Well every service mine usually goes back on the dyno every 5000km's... sometimes more or less, depends on the state of tune (this was the RB25, cant see the 26 being different)
This is a cheap alternative for peoples cars that might go on less often, i reckon $30 every 6 months to see if the AFR's and stuff look ok, is good and cheap insurance
Hey Ash,I imagine one of the reasons you get low numbers to dyno days is that only members are invited.What is the ratio of members to subscribers?
I also agree that running your car on a dyno every 5-10,000kms is a good thing,just to moniter everything is running right.
Cheers
well to the person not being arsed. Its a competition pretty much, will be awards like TOP SKYLINE, TOP VL TURBO, TOP SILVIA. Also TOP RB25, TOP RB30, TOP RB26 etc etc yada yada. Tuning is expensive. Just go out and have some fun. Cars will be on show (including mine and my brothers).
Cheers
All members get a mail.. but see the BBQ's are usualy free and stuff.
I mean, that said we had 20 i think last time.
anyhow... set a date lethlRB and put it in the Events section
well it wont be happening for the next month or so because its going to be organised when my brothers car is running. So we can put it on display and stuff. So i just want to see if alot are interested then i will go from there.
Hey, when u say members only does that mean paying members only or just ne1 that has registered. Also which workshop is it?
Its most likely going to be at DrDrifts shop with his new dyno.
I don't know why these events are members only as usually events like this should be a good way of signing up new members once they get a taste of the kind of events that the club runs... Plus having it open to non-members undoubtedly increased the turnout on the day - not to mention gives a chance to see a new car enter that could be more modified than the usual lot...
I would have to agree with this, mostly because I am not a member :)
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
