there is a scamer on ebay at the moment selling a stagea in cairns i bidded on the car and won but he wont sell it to me because i won the car for $13500. it's advertised for $22,000 in his car yard and on Ebay again under a diffrent name buyers beware he is a snake and will scam you no mater what he has all ready ignored a legal binding contract people like this need to be stoped. 4623580634 item no on ebay
vin6U900WGNC34000422
Its at Low Cost Cars 75 Sheridan Street. 40514090
his other alias is pumkin-scones
Edited by xr8eater
https://www.sau.com.au/forums/topic/110264-scamer-on-ebay-beware-stagea-buyers/
Contact ebay and tell them the full story...
Have heard of this happening before and ebay basiclly investigates and bans them from using their username and if they do it again and again they block the users permentlly (to sell you need to put down a credit card or a home address.) Either way report it to ebay....
what if the car is not in workin order or has faults or other problems??
worth checkin car in person, before biddin on an item..
Have you paid the amount already??
But contact ebay on your situation tho..
ouch 21 grand for that? $13,500 is probably closer to what it's worth. I saw an auction for this same car end a couple of hours ago, and it finished at $16,500 or something like that, with the reserve met.
Yeah, it's a legally binding contract. But if his details are dodgy, it won't matter. And when you consider how easy it is to create accounts on eBay and bank accounts with false details, it's a real jungle out there...
If I was buying something like a car, I would want the address where the car is for inspection and registry check before anything else. I've had a few poor encounters with eBay members myself, including still waiting on a high flow cat from a certain seller...
Just remembered with car sales on ebay...
They dont have to sell the car at all if;
1. Its sold out of a yard
2. Its advertised in newspapers
3. It has a private deposit on it
4. The sellers make up one of the above 3 reasons...
Anyways you report it to ebay and ebay contact him and he says i own a car yard and someone has come in and out a deposit on this car therefore he cannot sell it and thats the end of it.... However you must complain cause if he keeps doing it then he will be get banned.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
