so i got around 4k for my birthday and i really dont know what to do with my car.
im gonna spend around 1k for a full exhaust system but the problem is i wat a FMIC.
i was checkin out N1 in melbourne and the HKS coolers and they are around 2.3k. is that seriously worth it or should i get one of these. for around 600 (my mate says they good value)
http://www.justjap.com/parts_nintercoolers.htm
ill spend the extra money if its worth it....but not if its only gonna gain so little and i gotta pay like +1k
Edited by anjoO
https://www.sau.com.au/forums/topic/110286-4k-to-spend/
  • Replies 41
lol....i aint gonna be like 2f2f or anything.....but i just want good quality
kinda changed my mind a lttlel tell me what u think
Get an exhaust first.
Look in the traders section for posts by "BATMBL"
But a Split front/dump pipe, and a highflow cat.
Then get a catback system made up from your exhaust shop, and get it all fitted.
https://www.sau.com.au/forums/topic/110286-4k-to-spend/#findComment-2031784
yeah i think its too much. As dark said, make sure you get a decent 3" exhaust with hi flow cat. No need to go overboard with HKS or whatever
Also I have a Hybrid cooler kit and have had no problems whatsoever.
Edited by NathR32
https://www.sau.com.au/forums/topic/110286-4k-to-spend/#findComment-2031790
Im just about to buy some parts for my r33, so ive been looking into what to get.
I would go a twin dump/front pipe all in one (from a guy on this forum) also a high flow cat. Not sure on the rest of it probably just a 3inch.
Get a hybrid or a justjap intercooler kit.
Theres a guy on ebay selling a good boost controller for $35
That would cost around 2k
with the rest you could go for a power fc and get it tuned then you should have 500bucks to spend on a deck. Goto http://www.auaudio.com for some good deals.
https://www.sau.com.au/forums/topic/110286-4k-to-spend/#findComment-2031792
hRmmms....see all this is good i can spend 2k on all that. but my questions is, is it worth the money spending around 2.5 - 3.5 k on exhaust and cooler. will i gain alot from that big of a upgrade? or only so lil
https://www.sau.com.au/forums/topic/110286-4k-to-spend/#findComment-2031797
Can I make the suggestion of... Safty first!
hahahah tru that....now that u brought it up. i wanan get an electronic boost controller coz its easier and safer, what do u recomend thats cheap, but good quality. also whats a good rev limit? is it okai hittin 7?
Edited by anjoO
https://www.sau.com.au/forums/topic/110286-4k-to-spend/#findComment-2031814
If you want more info on the cheap boost controller go here http://www.skylinesaustralia.com/forums/in...=73375&hl=loose
I wouldn't think they are "unsafe" you would think a EBC would have more of a chance of not working. But its just an idea if you want to use the money you save on getting something else....
https://www.sau.com.au/forums/topic/110286-4k-to-spend/#findComment-2031831
I meant good tyres, good suspension, good brakes, make sure all bushes etc on the car are in good nick.
Really $4k can go far, or not really anywhere. In terms of performace I would have spent $1k max on the engine, and got the most out of it. Just doing the right mods getting good gear, and paying the right price for it. But then suspension, brakes, gearbox, everything else is up to scratch.
Just my oppinion anyway. Even split it up a bit.
https://www.sau.com.au/forums/topic/110286-4k-to-spend/#findComment-2031868
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
