  • Replies 47
Mate i did buy the Splitfires for the RB20/ series 1 RB25, but was able to swap them accordingly for a Series 2 RB25.
So if that is the case the coilpacks coming off the RB25 won't work :thanks:
But I can always ask what condition the coilpacks are like coming off the RB20......
Ando
Edited by R33Deviat
UPDATE - 28/03/06
After numerous discussions over the engine, it seems it is no ordinary RB25DET :D It seems it is a very legit low KM engine, so 24,000 seems to be accurate! It apparently is a VERY VERY LATE model RB25DET off a Stagea WGN33 with the sump modified for RWD..... :O
A few additions to the add-on list...
1. RB25DET
2. R33 GTST Gearbox
3. FMIC
4. Splitfire Coilpacks
5. 3" Exhaust Turbo back
6. Ceramic Clutch
7. 2 x Recaro's
8. Oil Cooler Kit
9. Profec B II Boost Controller
10. x3 Guages - Oil Temp / Pressure & Water temp
WATCH THIS SPACE FOR THE NEXT UPDATE! :(
Ando
UPDATE - 28/03/06
After numerous discussions over the engine, it seems it is no ordinary RB25DET :huh: It seems it is a very legit low KM engine, so 24,000 seems to be accurate! It apparently is a VERY VERY LATE model RB25DET off a Stagea WGN33 with the sump modified for RWD..... :)
Stageas came in RWD RB25 as well (just no one in australia seems to like or know about em), as did C34 Laurels, Glorias and Cedrics. Its pretty strange to modify an AWD RB25DET to a RWD when you can just get a RWD one cheaper and more easily.
Also the late late model RB engines are NEO engines, so make sure you get the right parts for it (eg: top feed injectors instead of sidefeed like regular RB25DETs).
Shan,
Mate it has me lost as to the exact nature of it.... I will see if I can get a piccy of it up for you guys to ponder over
Here you go!
:):huh::)
Ando
Edited by R33Deviat
Thanks heaps Nick!!!!
Yeah she is coming along nicely!! :) Just gotta feel sorry for Nath having to sort thru the wiring loom to match up to the RB25! ( See last 2 photos )
Doesn't a wiring loom hanging off the exhaust add about 2000+ rwkw?? :D
Ando
  • 1 month later...
*UPDATE 08/05/06*
Pit stopped @ the workshop on the weekend to pick up the RB20 / Gearbox and see my baby :worship:
Should be done in a few weeks time WOOT :spank:
It is 100% confirmed, engine is WGN34 Stagea RWD.
Just awaiting a couple of things such as, driveshaft modified for the 33 gearbox, power steering pump etc. Engine should be getting turned over in the next couple of days!
As for price (Basketcase) approx $4000 for engine (22K Km's), gearbox, coilpacks, full loom, AFM, ECU, delivered. Wasn't fussed paying a little extra considering the very low legit km's.
Ando
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
