Woa... Thats pretty good - Im just curious due to the strapping my car cops, the engine won't last forever and I'd love to know what im in for eventually...
I need an R33 Box!
Good luck with it!
  • Replies 47
Cheers dude.....
I went thru a couple of gearbox's within the 12 months of owning it..so looking forward to having a bigger, stronger 33 box in her!
Ill update with some piccies once i get it back in a couple fo weeks
OKay car to be back in my hot little hands very shortly! And i have even gone and got some semi slicks for her to use on the 15"s and just purchasing a second set of 17" Work rims....
Will have all the photos of her after her little steriod injection withina couple of weeks!!
SO EXCITED
BIG KEV EXCITED!!!! :fakenopic:
ahahah yeah been on a bit of a spending spree but i figured i might as well do it all now (well for quite a few months lol), instead of bit by bit.....
So should be getting the car back this week, first test drive is tomorrow, failing any huge issues should be good to go!
For those interested, list of things done are :-
1. Engine / Transmission
Series 3 RB25DET
R33 GTST Gearbox
Ceramic Clutch
FMIC 600 x 300 x 100
Oil Cooler
Splitfire Coilpacks
3" Exhaust Turbo back
2. Other Bits N Pieces
Profec B II Boost Controller
x 3 Guages - Oil Temp / Pressure & Water Temp
x 2 Recaro's
3. Handling
D1 Coilovers
x 4 Work CR Kai 17x8 +32 (Daily Rims)
x 4 Toyo R888's Semi Slicks on SSR 15" rims (Track rims)
4. To be done within a week of having car back
Window Tinting
Guards Rolled
Driven Driven Driven & Driven some more :(
Would like to get hold of some strut braces & camber arms, tie end rods etc too, but will see how that goes. Hopefully all got before Wakefield :D
So will have some piccies up hopefully very soon!
Catchyas!
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
