It isnt a head gasket as im running a 3 layer metal one, and the head has been fully rebuilt less than 15k kms ago.
Water temp is always 80-85 deg. Only goes up to 90 on a hot day. No leaks anywhere in system.
Only thing left is the cap...which i havent found a replacement yet, as repco tried to sell me something that was different to the one on my car, even after i pointed out it was different....damn ignorant sales jerks think they know everything
I have been having the same problem with my car and after alot of messing about changing the radiator cap and thermostat i decided to take the radiator off and get it flow tested to find it is partly blocked so ive just left the thermostat out untill i can find a new radiator or get enough time off work to get mine recored
I think I can tackle this little problem but you have to do what you are told.
1/ Get rid of that stupid push button radiator cap. I use a Mazda 121 cap, it's 1.1 bar (standard is .9) Nismo and the like are 1.3 bar.
2/ Fill the overflow bottle to the top make (max) on the bottle while the car is cold. Now go for a drive. After the drive check No 3. If this turns out good (make it a every long look) go to No 4.
3/ I would assume you are running quality coolant. If you have any leaks it will show up with a white dry residue under one of your water connectors,,,,meaning hoses, joints and even from the water pump.
4/ Get the system pressure tested, if still nothing
5/ Get a mechanic to leak test your engine telling him what you have done so far and hope it's not a head gasket. Just because everything is new is no garantee it's all good.
Hope that helps.
Neil.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
