Guys, my gtr has been sitting around for a while without being started, and i tried to start it today - no suprise, a flat battery
So i get the jumper leads from the other car and hook them up, the voltmeter shows almost half way, i turn it over and the starter motor is working, but the engine wont fire up
What would that be?
The manifold pressure keeps rising as it tries to start ive noticed.
I cant roll start it - so that is out of the question
Thanks in advance
https://www.sau.com.au/forums/topic/110357-rb26-turns-over-but-wont-fire/
What would that be?
Thanks in advance
Not enough voltage/current?
Turning over slow?
Try a better jumper battery, larger jumper leads or charge the battery overnight.
:P cheers :D
PS, you're a naughty boy, you should drive your GTR everyday.
It turns over at normal speed to start, then gets slower until theres nothing
Ive tried letting it charge for a while, but nothing
I also noticed the tacho goes spastic when the starter motor is trying to start the car
How would i charge it overnight?
Your also trying to push power from the jumper battery through the dead cells of the other battery. Overnight charging will be needed, also the cranking will be filling cylinders with fuel....not good for the plugs.
i had my car off the road for 4 months while respraying... then it never idled again after that ..
ECU shat itself somehow, didn't work til i changed to pfc..
battery for sealed 550CCA should be around $140
Steve, my car went flat while I was in Japan and there wasnt enough current left to jump it, or to register a charge using the trickle charger.
I got around it by connecting jumper leads at the back, connecting them to another car to get charge going in, then connected a charger to the terminals in the engine bay, which then registered charge.
Left it for 24 hours and hey presto :)
That said, it sounds like there might be another reason for your car failing to start :)
