yo,
My car runs really slow? its a R33 gtst...TURBO.
Ive tested a 0-100km time and it does it in the high 7's and low 8's?
Why is that?
I haven't serviced the car since 15,000 kms ago (I know, bad)
But would a full engine service help my car perform better? I.e chage spark plugs, clean throttle body, clean injectors, change engine oil etc??
Thanks!
Yes.
And you haven't stated your mods, how many k's your car has done, your cars current power output, suspension setup/state of, way you're measuring your times and the way you're driving your car in order to get those values. Also if your car is running funny, ie currently exhaust leak etc.
If you provide all this information you'll probably get alot more help from the guys on here.
-Insu
my bad
Um, its a 94 skyline, auto, dragger exhaust, and 10 - 12psi boost. bout it.
Its got a whole in the exhaust somewhere...and the radiator is leaking. thats it..
115 000 on the clock now
But yer, i can barely pull away from v6 commodores.
thanks
get the hole i ur exhaust fixed or get a new system, just a question where does the temp gauge sit?, if u have a leaking radiator this can result in it not pressurising properly, i had this problem in my VL, hole in zaust made my car use more fuel an run like a bag of spuds on wheels, i couldnt even beat a berina.
Take and get a full service and check up and maybe an injector clean
tell them to check all air box bolts and intercooler clips new plugs and get them gaped and get the hole fixed in the exhaust system
james
Also, the times posted for an R33 0-100 times in the high 6 second mark are for manual cars, you'll loose a bit (up to a second by some reports) of power through the auto box, it's just the nature of them.
If you got the car all serviced and running well, i'd expect times in the low 7's with an auto would be reasonable.
Get the car dyno tuned to get a good idea if the actual power output for the car is healthy or not, that way you can also check your fuel air ratios as well.
-Insu
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
