When the car gets really warm (20 mins of driving), mine is anything from 90 to 95.
Oil pressure when I start the car is 6ish. When it gets warmer itll idle at 2, when you revv it a bit, pressure increases to around 4.
wot if the oil pressure moves higher than that?! wot could the cause b... :P
Usual oil temps are btw 80-95deg. When driving hard with 38-40deg ambient temps can see 110+ but drops quickly with an oil cooler once you back off.
Higher pressure is fine....its low pressure you gotta worry about. When pushing hard on high boost I can see pressure of 8 on my gauge
