Hey guys and girls,
I have a mate that has a corolla who is turbo'ing a 20V motor.(I know its not a nissan but you guys have so much tech information it overwhelms me!!) I used to own a S13 by the way lol.
Anyway, he wants a responsive turbo that can start spooling around 3000-3500rpm and which is capable of 600hp. He also wants to know if he is running this much power will the VVTI still be usuable for the power band(rev out to 8500-9000rpm) or will it be unusable or would it just not be worth the effort and just ditch it? What turbo would you guys recommend and can you comment on the VVTI question?
Thanks champs.
Kory.
https://www.sau.com.au/forums/topic/110403-quick-question/
Well he is aiming at 350kw. I know a few people with around 250fwkw with turbo spooling at 3500rpm. I just want to know what turbo you guys would recommend for 350 and will the VVTI work or should he ditch it?
https://www.sau.com.au/forums/topic/110403-quick-question/#findComment-2034390
http://toymods.org.au/
this place knows nothing about the 4A-GE range of engines.
and you have to word it better.
saying a "turbo spooling at 3500rpm" to me means nothing.
so do you want it to start making boost at 3500?
do you want it at full boost (whatever that may be) by 3500?
the only 20v corolla that's been turbo charged with shit loads of power that I know of is a girl called SAM (who is the wife of Tony Rigoli)
so maybe you should get in contact with them and ask them questions as they will know.
I believe her car has run 11's on slicks.
I doubt VERY much that she has any form of positive manifold pressure (spool boost bro) at 3500rpm.
There is also a 4agte (turbo instead of supercharged), AW11 MR2 that runs some ridiculous numbers.. I think it is low 10's at the moment.
he had something in the GT30 range of turbo's..
still on the 1.6L.
no.. it did not spool at 3500rpm.
https://www.sau.com.au/forums/topic/110403-quick-question/#findComment-2034886
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
