  • Replies 49
motor is standard
-35/40 turbo
-Plenium
-700 cc Injectors
-LOL GAS
-ummmm yeah
i am trying to get the thing to hook up off the mark
im doing
1.8 60 foot times
pretty shit if you ask me
i am aiming at 1.5 even 1.4
im working on a new suspension setup
and the car needs higher gearing 4.86 or so as im only crossing the line at about 6000 RPM (need to be 7800 RPM)
then after that im gonna try and pull some weight out of it
get it to 1200 KG then run again
hopefully it should crack 10.6`s
Edited by MR331307
Nice one Moanie.
Adrian = boring :D:P
I wanted to come but I didn't want to jinx you all and bring the rain. I think I'll go again next week. In my dream I went and it rained again so that's a sign I think - it will rain every time I go or say I'm going. :P
yeah, I woul have loved to have improved my times with a couple more runs. I thought I could have gotten another three runs in at the end of the night and made it 10 runs for the night :P
Well doneMoanie and Adrian. Best of luck in Qld on Saturday Mr Happy Happy Gas.
Well done also to Jason with the 11.3's :D
Yesss!!! well done jason :) and nice to meet you :(
hahah.. charlie... i reckon!!! the official said 2 more runs for sure! then that damn rain came down!! oh wells.. i got 7 runs all up so i'm happy :)
and i swear when you said you had a mitzu, that you were going to be in an old rickty 4 door thing! LOL!
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
    • It will be salvageable. It really doesn't matter what is damaged. Opening up a 30+ year old motor for a rebuild immediately means a complete rebuild of the head anyway. Damaged valves just means an opportunity to put in some nice new ones. And in the modern day, why would you not throw at least a nice set of pistons at something. And if you're doing that, why not rods, and ARP fasteners, and so on.
