Updated: 18/05/06
Disclaimer:
This information is provided for your information only, anything you choose to do with this information is completely up to you and in no way will I, Skylines Australia or any affiliates be held accountable for following said actions, causing damage or harm to you or your car.
Introduction:
There have been numerous references to cleaning your AAC (Auxiliary Air Control) valve on your skyline on these forums, however I have noticed that many of these descriptions are fairly basic. As I was going to clean mine anyway, I thought I'd photograph and document the process so as to provide a tutorial for those attempting this themselves for the first time.
This isn't an overly hard thing to do, any many people with a basic knowledge of mechanics (Ie. Me) would be able to wing in without a manual, but nevertheless, if this DIY was available for me before I started, I would have used it.
Why clean your AAC Valve/ What does it do?
When your RB series motor is warmed up and idling it is your AAC valve which controls the amount of air entering your engine in order to control your idle. The best description I can think of for one of the things that your AAC valve does is if you were to sit in your car, stationary at idle and turn the steering wheel. The throttle blips in order to stop the power drain taken from the power steering stall the car. That blip was the AAC valve letting more air into the engine, bypassing the closed throttle body. Check (if you live in usa): Costco Weekly Ad, or Supercheap Auto Catalogue.
There has been much said about dirty/faulty AAC valves causing or attributing to idle hunting issues and this was my reasoning for cleaning my valve. This isn't the only cause of poor idle issues, but it can definitely attribute if not cause poor idle/ hunting idle issues.
Basically over years of use, carbon deposits rising from the engine, minute grit etc from the intake builds up around the valve and causes it to work in less than ideal conditions.
(Note, this is not the valve which controlls cold start revs on idle, that valve is connected inline on the same intake pipe as the AAC valve but is situated under the intake plenum on RB25's)
Car in Question:
1993 Model Nissan Skyline R33 GTS-T (Manual)
Difficulty Level of DIY:
Low-Med
Time Needed:
Budget at least one and a half hours, longer if its your first time.
Materials/Equipment Needed:
-Torch (A must for finding those stupid bolts)
-Ratchet Set
-Philips Head Screwdriver
-Flat Head Screwdriver
-A Tray to Hold the Bolts
-Carby Cleaner! (Don't even bother if you don't have this)
-CRC Cleaner (Not a must, but I like to spray the electrical plugs with this while they're off)
-Gasket kit or Gasket Goop (Again, you may not need this providing your gasket holds together, mine did, but it will vary obviously from car to car)
Thanks to Justin911 for the gasket number from nissan (if you need it): 23785-57Y00
-Cotton Wool Buds
-Air Compressor/Air Gun (Not 100% nessecary, I just used the cotton wool buds instead, this would just make the job faster)
-A pair of pliers (For removing hose clamps)
Procedure:
1) Pop the Bonnet.....duh
2) Locate the AAC Valve & Assembly at the rear of the plenum (near firewall), see below picture its circled in red.
3) Before you remove the bolts that hold the AAC valve assembly to the side of the intake plenum, there are two electrical plugs and two intake (ones actually an output that goes to the cold start valve) that need to be removed, the plugs are red(browny) and purple you can't miss them (see above pic).
4) Before you start to remove the pipes from the AAC it's a good idea to remove the two other pipes infront of the AAC can get in the way, ones a Vac line and the both come out pretty easy, it just make life easier when getting to the bolts and pipes on the AAC (circled in yellow in pic).
5) Remove the pipes going to the AAC Valve, circled in blue. They're a little finicky.
I found it was easier to remove the pipe that goes back to the intake at the place marked with the blue circle, then once the AAC assembly was out, to remove the hose at the base of the AAC itself for cleaning.
6) Now using your ratchet, you need to remove the three bolts holding the AAC assembly on to the side of the plenum.
One bolt is on top, the other two are underneath, you can partially see one but you'll really have to find them by feel. See some of my later pictures of the AAC assembly removed if you want to see exactly where the bolts are in relation to the assembly.
7) Once the three bolts, 2 hoses and two plugs are removed you are ready to pull the AAC Assembly off of the side of plenum. Be careful if you want to re-use your gasket. (see pic)
8) Hooray its off! Take a look inside the valve, mine was pretty filthy (see pic) its no wonder after 13 years of driving! This could definitely do with a good clean, I could already see it was far from optimum.
(Note in this picture I've already removed the AAC valve from the AAC Assembly as described in the next step)
9) (I presume you've already removed the other half of hose as described in step 5, clean this pipe with cleaner too).
Its time to familiarise yourself with the operation of the AAC valve and Assembly, basically there are 3 parts. Held on by two screws is the AAC valve itself, you can remove this now, but be careful as there is an o-ring between the assembly and solenoid (DON'T LOOSE THIS). Check (if you live in usa): Publix Weekly Ad, or Big W toy catalogue. There is the Assembly itself and you can see there is a spring inside there with a diaphragm above it that when the solenoid activates it, pushes against the spring and opens the diaphragm allowing air in the intake pipe through the assembly and into the intake plenum.
On the bottom of the AAC assembly there is a screw, this can be removed for cleaning and is generally the dirtiest part as this is the idle control screw. At all times when idling the tiny gap that the screw when in allows air to pass through keeps the car at its steady idle. It's no wonder there is so much buildup.
(See pics, AAC solenoid by itself removed and circled in red the location of spring, diaphragm and idle spring, note you cant actually see the idle screw in this picture)
10) Its time to clean the assembly, carby cleaner time!
Be liberal, it might take a while for the crudd to break down as its really baked on there, but eventually it all comes off, as I said before, I used cotton wool buds to get to the harder spots but an Air compressor would most likely work much better. Make sure you manipulate the spring and diaphram, and make sure all those areas are clean as well as the pipe intake and out pipes. Also clean the idle valve screw (you'll see its hollow down its centre)
Wait till the whole assembly is dry and make sure again its all clean. Check the smoothness and operation of the spring and diaphram.
Clean the machined faces that face both the intake plenum and AAC solenoid to leave a smooth surface.
Check out my pics of before and after of the dirty valve and then cleaned, its a big difference, trust me! Especially in regards to the operation of the spring and diaphram.
Before
After
11) Now its basically the reverse to put is all back together, ensuring all faces on the AAC Assembly are clean, re-attach the AAC solenoid ensuring you have the o-ring in place. Re-insert the idle screw, be sure not to overtighten this, but it in to an amount where you can just see the end of it protuding into the plenum intake hole, we're going to adjust the idle properly later.
12) Make sure AAC Valve and Assembly is all dry and free of loose debris one last time, re-attach unit back into car in reverse order as above, ie: Pipes first, Install new gasket if needed, install bolts (DO not overtighten the bolts!).
Before re-attaching the electrical plugs give them a quick spray with CRC if you have it, and let it dry.
Also make sure you re-attach the two pipes we removed earlier in order to make getting to the AAC easier.
And we're done! Now its time to set the idle!
13) Now there are two ways to set the idle, the long proper way and the short easier way. I did the long proper way, but it's really up to you which you'd like to do. (NOTE: I HAVEN'T ACTUALLY TALKED TO A SINGLE PERSON WHO SAID THEY NEEDED TO DO IT THE LONG WAY, ITS PROBABLY NOT WORTH DOING IT STRAIGHT UP, JUST GO BACK AND DO IT IF NEED BE)
Basically in the long way you have to remove the kickpanel in the passanger footwell, remove the computer (while still connected) and locate the electronic idle tuning screw (see pic) DO NOT UNDER ANY CIRCUMSTANCES APPLY TO MUCH FORCE TO THIS SCREW, IT TURNS VERY EASILY!
14) Once you've located the screw, you'll see it can move through about 70 degrees, it should be pointing towards the bottom left corner, do not turn it past 12 o'clock. If it is already facing as far left to bottom as it can, turn it ever so slightly clockwise, just a smidge. Now turn the car on and warm it up, your idle may be fairly high depending on how far your idle screw is in, don't worry about this too much as we just want to warm the car up for now so we can work just on the AAC valve without the coldstart valve interfering.
BTW this is a picture of the Idle screw if you haven't figured out where/what it is yet (you should have if you cleaned it!)
15) Once the car is warmed up disconnect the TPS (Throttle Position Sensor) See pic below circled in red, it is on the opposite side to where the throttle wire rotates the throttle butterfly. (Note if you have an R32, the connection you have to disconnect when adjusting the idle is actually the brown electrical connector on the AAC assembly, not the TPS)
See where the car idles. Now depending on where it's idling depends how you turn the screw (AAC one, not the computer one), turning it clockwise lowers the idle, anti-clockwise increases idle. You want to aim for 900rpm. Once you have this by adjusting the AAC idle screw, reconnect the TPS connection with the car running, see if the revs change. If they do, you're now going to have to adjust them on the computer (see this is why we got it out).
It's the OPPOSITE on the computer to the AAC valve screw: Clockwise=increase idle, Anti-Clockwise=decrease idle.
You can move the idle in 50rpm increments so I'm told and at total variation of 250rpm, so DO NOT OVERTURN THIS COMPUTER CONTROLLED IDLE. This is only a fine tuning mechanism.
I didn't actually need to move my computer controlled rev, as my revs didn't change once I put the TPS electrical connector back in.
16) All sitting smooth? Turn the car off, put the computer back in its kickpanel, re-check all connections in the engine bay to make sure they're all tight etc.
Start the car up again and check idle.
Mine was sitting steadily on around 800rpm, perfect for me.
17) Obviously the easier way of setting your idle would be to do all of the above, minus the computer step. If it needs it, you could go back and do it properly.
18) GO FOR A DRIVE!
I don't know about you, but this has actually fixed my idle hunting issue, not to mention my car doesn't shudder or hesitate when coming to stop and pushing the clutch in anymore. Feel free to give me some feedback about your experiences with this DIY and how it has affected your car.
I hope this DIY has helped, please ignore my bad spelling and grammar!
-Insu
Edited by Duncan
  • Like 1
  • Thanks 1
https://www.sau.com.au/forums/topic/110431-diy-aac-valve-cleaning-idle-reset/
Just performed this today on my 33; went well, didn't take me too long. Was definately dirty inside, nice and clean now. All that's left for me is to do the idle reset but I'll do that tomorrow...
Thanks for the guide
I just also did this today and let me say it has fixed all my idling and stalling problems in a nut shell.. I honestly didnt think it would go so well after the cleaning and all.. thanks a million for this DIY.. definitely keep this DIY on my computer.. thanks again!
:mellow:
Wow that was a super write up man, great job!
I just had a couple of questions and hopefully you'll be able to answer them.
1. I have an RB20det, will this process be the same on this motor?
2. Does the adjustment screw work the same way on my engine? I will be using an atmospheric bov soon and I thought about turning the idle up a couple hundred rpms to help with stall out issues. I did that on my 240sx and it worked great so I'm wondering if it can be done with my Skyline.
and lastly, I don't have any idle issues but by adjusting the screw on the motor and NOT the ECU to turn the rpm's up (for the bov purpose) when I reset the ECU will that cause any issues or no?
Thanks for this in advance and again, VERY NICE write up. :P
1) I'm not sure about the RB20det being the same as the RB25det. It would be good if someone could find this out for me and post up pics etc if they're different. If you look up at the posts replying to this thread there was a guy talking about how his RB20det doesn't have a spring inside its AAC assembly. So in answer to your question? I'm not 100% sure. It shouldn't be too hard to figure out if the system is just slightly different though.
If you do go ahead and do this to your car, i'd appreciate it if you could post up some pics of any differences and your experiences!
2) As for the idle adjustment screw, to my knowledge this is the same process on the R32 as the R33. As for turning your RPM up a few hundred at idle to counteract for a Atmo venting BOV, I don't really see how this is going to fix your problem.
The reason for this is as follows: When idling, your bov should be closed irrespective if it is atmo or plumbback, henceforth there should be no leak. Therefore your AFM will read the same eitherway, it won't have a false signal due to the BOV.
It's when you're driving that the lack of air being entered back into the inlet can cause problems. In this case, I'm reasonably certain that any differences that the extra air being let in by the idle bypass screw inconjunction with the amounts being lost from the atmo BOV will be insignificant.
In other words, I still don't see how it would help you.
Your best option would be to get at least part plumbback, all plumbback or get the ECU tuned to recognise that the air will not be there.
However, there may be something here that I completely overlooked.
The only reason I can think of why this might have worked on your 240sx is that your BOV was leaking even when idling and meant to be 100% closed, and the idle bypass screw increase was just the amount needed to counteract this vacuum leek.
3) Again as in part 1, i'm not even sure if the R32 has a finetuning mechanism for idle on the computer! easiest way to check I suspect would be to check it out.
The idle finetune on the ECU is just that, a fine tune. It's not meant to be used for anymore than a total 250rpm I think it is.
And in answer to your question about resetting the computer resestting the idle on the computer? No it should not, it is mechanical control on the computer (Read:physical adjustment by the screw) and should not change.
Hope this helps.
Edited by insu
Bloody awesome article mate.
I havnt performed it yet but my new engine hesitates and wont stay on a steady idle. I have done coils, plugs, fixed vacum leaks and manifold leaks (both exhaust and inlet) The car boosts up a bit better but around 5000rpm it hessitates like its hitting a limiter or something and on idle it jumps around and sometimes stalls.
Ill give this a go tmrw.
Very appreciative of the time it must have taken you to post this up and ill deffinantly save this on to my computer.
cheers
did anyone notice on there r33 theres no gasket... ?
ive checked on a few and heaps of them dont seem to have it... ?
there should be a gasket, mine was suck to the plenum........ they would all have a gasket or use a sealant of some type or otherwise you would have leaks!!
Hey thanks for the input insu I appreciate it.
The bov on my 240 was'nt leaking though and by turning up the idle, when you let off at wide open throttle, it did'nt allow the rpm's to drop to low and thus cause the engine to stall. The normal idle was round 700rpm's ish (simliar to the RB) and dropped by 500-600 rpm's when I let off the gas. So with it going that low, the engine would stall. Once I turned it up that provided me more of a cushion and aided in preventing a stall. I do completely understand what you wrote above though and it could very well be true too.
Oh well, all I can do is run the atmospheric bov at regular idle and see what happens. If I find that I am stalling out I'll turn up the idle a little and see the results from that.
I did'nt think adjusting it from the screw would effect anything whenever I reset the ecu but I wanted to ask just to be on the safe side.
Again, thanks so much for your help man and I'll keep you posted on this as my bov is coming in this week.
Take care brother.
Cheers
anyone no the part number for the gasket ?? ive tried 3 nissan spares in vic none of them seem to no what im on about..
If you're still having trouble, try Trevor from the parts section at Nissan Brighton 9563 9977. He is pretty good with the whole import scene. Might need to get it from Japan though.
Good Luck
If you do find a place that has new ones available post it up as others may want one :D
on my 32 i pulled apart the aac valve and cleaned it out. Connected it back together but still cant get the idle under 1100rpm.
The ecu is turned anticlockwise all the way. the idle screw is all the way in. the throttle butterfly is back as far as it can go and i still cant turn it down. I can get it down if i disconnect the aac valve but when i connect it it jumps to 1100rpm idle.
CAn anyone help?
Ryan
It could also be a vacuum leak.
If your idle screw is completely closed, there is definatly somewhere else that air is entering into the inlet manifold.
As was said above, my bet would be on the cold start idle control, or a vac leak, or for some reason a malfunctioning AAC assembly, where it is sitting open far too much when idling. Try disconnecting the power to the AAC assembly, that should close it and give you an idea of where the leak is comming from.
The car should stall if the AAC valve is faulty and opening too much, when you unplug it.
If that doesn't work, try pinching the bottom hose that runs past the AAC on its way to the cold start, if the idle drops when you pinch the hose = less air = stall, then thats your problem.
If that still doesn't work, check all your lines for tears or holes. Check all your gaskets on the inlet manifold, and check your throttle plate is properly closing.
thanks for the info, spoke to trevor and he sorted it all out :thumbsup:
incase anyone needs it , the part code for aac valve gasket is - 23785-57Y00
Good Luck
If you do find a place that has new ones available post it up as others may want one :)
thanks for the info, spoke to trevor and he sorted it all out :(
Hey if you don't mind i'll add that part number into my main post.
Did he give you a rough price too by any chance?
Thanks
    • Thanks for the info GTSBoy, legend. If there is no downside i'll likely just get the larger bosch units because why not... I remember hearing stories about people washing their bores with fitment of too large injectors way back when, which i guess has made me shy about it now. But happy to know it shouldn't be an issue. Ozdavroz, the little rb20 is a lot of fun- now that i have a little extra funds and time i am very glad to be tampering with the ol girl again, after so long. More RB20's on the road the better. Cheers, Rowdy
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
