^ all good my boss mate found the bolts in bunnings... anyways results of clenaing the AAC is freaking awesome !!!!!! my car was like idle at 600 rpm for the last year or so and always started hunting when I used Aircon/heater this has fixed everything, cars running good as new !!!!!!!!!! thanks for the write up great guide.
Your mate sounds like his pretty awesome :D
  • 2 months later...
  • 1 month later...
I was having issues with a rough idle after start. Revs were sitting at 4-500, or the car would cut out. I'd blip the throttle, then they would pick up to 1200 or so before settling down. I came across this thread whilst troubleshooting, and it sounded like the AAC valve needed cleaning. However, I found a leak on the vacuum line between the throttle body and charcoal canister (tiny...only a few mm), Replacing that hose has fixed the problem. Sure it has been said in this thread before...but check for leaks, might save you unbolting the AAC!
  • 1 month later...
  • 10 months later...
  • 4 weeks later...
  • 2 months later...
  • 7 months later...
  • 1 month later...
I wanna give my a car a clean this weekend too. If the gasket is not really re-usable, can we use one of those tubes you get at auto stores for making your own gaskets? Also should it be hardening or non-hardening?
On another note though could someone help me out with what the hell is going on with my aac valve? This is the third one that I put on there because I thought something was wrong with the aac valve itself, at idle it keeps on hunting as in the revs go up to about 2000 then down to 1000 up and down up and down, if I turn the headlights on it idles fine at 1000rpmish, I've just unplugged it for now and it's idling at 900 bit i really want to get it sorted out as its getting hot and when I turn the ac on the aac valve being unplugged doesn't compensate for the rpm drop, thanks.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
