^ all good my boss mate found the bolts in bunnings... anyways results of clenaing the AAC is freaking awesome !!!!!! my car was like idle at 600 rpm for the last year or so and always started hunting when I used Aircon/heater this has fixed everything, cars running good as new !!!!!!!!!! thanks for the write up great guide.
Your mate sounds like his pretty awesome :D
  • 2 months later...
  • 1 month later...
I was having issues with a rough idle after start. Revs were sitting at 4-500, or the car would cut out. I'd blip the throttle, then they would pick up to 1200 or so before settling down. I came across this thread whilst troubleshooting, and it sounded like the AAC valve needed cleaning. However, I found a leak on the vacuum line between the throttle body and charcoal canister (tiny...only a few mm), Replacing that hose has fixed the problem. Sure it has been said in this thread before...but check for leaks, might save you unbolting the AAC!
  • 1 month later...
  • 10 months later...
  • 4 weeks later...
  • 2 months later...
  • 7 months later...
  • 1 month later...
I wanna give my a car a clean this weekend too. If the gasket is not really re-usable, can we use one of those tubes you get at auto stores for making your own gaskets? Also should it be hardening or non-hardening?
On another note though could someone help me out with what the hell is going on with my aac valve? This is the third one that I put on there because I thought something was wrong with the aac valve itself, at idle it keeps on hunting as in the revs go up to about 2000 then down to 1000 up and down up and down, if I turn the headlights on it idles fine at 1000rpmish, I've just unplugged it for now and it's idling at 900 bit i really want to get it sorted out as its getting hot and when I turn the ac on the aac valve being unplugged doesn't compensate for the rpm drop, thanks.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
