INSU first i'd like to start by saying TOP write up. Everybody has said clean the AAC and i know my way around a car but really didn’t know were this was actually located. The pics really help.
My car had really rush idling would pulse, also when i had the A/C on and would put the clutch in at the light would 99% of the time go to stall.
I thought it was my coil packs or even spark plugs, also their was like a flat spot when I would excel. I didn't realize by cleaning the AAC that all these problems would go away. You cold not wipe the smile of my face from the result :thumbsup: . I didn't even need to adjust the idle was perfect after cleaning. My car feels like it runs much better. Took me around 2 hours, i really mad sure it was clean.
I WOULD RECOMMENT THIS TO EVERY SKYLINE DRIVER.
DO IT!!!! You will not be disappointed.
So I take it the basics of this work for the RB20 as well?
Also if I cant get a gasket, is there anything else I could use? Nutragrain box cut out or something simple like that?
You should be able to purchase a blank gasket sheet from pretty much any car shop, and trace out the gasket you need from the AAC assembly face, or trace off the old one.
I've heard of people using cardboard as gaskets.... but why bother, when the real deal is so cheap?
Because they do what my mate did, take it all off on his only car, then realise he needs some stuff... Including gasket paper. So cardboard it was to get him down the shop!
Thanks tho.
Have used cardboard (manilla folder type) for many gaskets... Only ever used it with proper gasket goo, like you're meant to with cardboard type gaskets anyway... But never had any trouble.
Back O/T, this made a wonderful difference to my car - having access to an ultrasonic cleaner definately makes it easier!
  • 3 weeks later...
Well I did it today. Was a little better, but then mine didnt look all that dirty.
RB20 its basically the same, just one extra bolt, only need to take one hose off, I didnt need to take any others off. Had I not stuffed about and had lunch inbetween I reckon you could do it in about 30mins. I found the cotton buds helped take a bit of the gunk off. It dryed out pretty quick in the sun. Hey its carby cleaner it just drys quick!
This really did help tho, its easy enough but its good peace of mind.
so... THANKS!
I'll be doing mine in a couple days too. I've been suspecting I've got a vacuum leak, but I'm going to be doing this first as I think it may need it.
If I'm lucky this may be all my problem is.
Just curious, when we take the screw out does the whole spring just pop out??
Got any pics of when you taken the screw off??
Btw awesome write up and very detailed, which is what i like when reading..
nah the screw just comes out, everything else stays intact.
  • 3 weeks later...
Ive found something really odd when I went to set my idle valve this morning. Looking at my ecu, there doesnt seem to be any idle adjustment valves or is there any blinker to give you signals when you do a diagnostic.I took of the plastic cover that protects the holes and there is nothing behind it. I have a series 2 r33 but that shouldnt make a difference. What the FUDGE!?
Hi all
Been reading all the posts on the forum and they are top notch! we hardly get any 'instructions' as such on the uk forums...
Anyhow, wondering if anyone has any ideas... followed this post after for setting up, but have a 32 gtr with high idle... Litterely have just resealed the inlet and plenum etc gaskets and renewed all the larger vac hoses under the plenum, new clamps etc... and well, done the setup procedure with modifications for the 32 (disconnect aac rather than tps) and she still doing the same, and to get the idle to around 1200rpm the aac is fully wound in. I know my aac and air regulating valves working (Can adjust and see working on laptop) but still can not get the idle down. Any ideas / common thoughts on the gtr ? Have looked over for vacuum leaks but cant see any, sits at around -500 on boost gauge (-5 on std centre gauge)
cheers all :dry:
In the bottom left hand corner of the pic you have there, if you look closely, you'll see there is a screw inside. That is the adjustment.
It looks like you still have the plastic over that side of the ECU, which is there to protect the controls, you should be able to peel it back to gain access to the screw.
Guys after talking to a few people, most say that the idle adjustment on the computer is hardly ever nessecary, and is only for tiny adjustments. If everything is working fine, the adjustment on the AAC screw should be fine.
Hi all
cheers all :D
Hey man, I'm really not sure, I'm also not 100% sure if this is the method for setting the idle on the R32 GTR, (As far as I know just the Gts-t).
You might want to post your problem somewhere else in the site, like general mat, you should get some more helpful responses!
followed this tutorial and got my AAC valve off without too much hassle and it were proper coked up!! Getting the pipe off the bottom is a bit of chew on but take the big one off first near the purple n brown plugs and it aint too difficult. Lost my blue O-ring as well for about 20minutes but found it in the end hehehe!
its made a real difference to the idling of the car and I only had to make a small idle adjustment to the idle screw on the AAC to get it back to 600-700rpm idling point. The car also seems a touch smoother when dawdling along at 5-10mph in slow traffic so thats made life alot easier hehe!
thanks for the very tidy and neat tutorial insu :D if you've any more tutorials you can point to on this site regarding maintenance of yer gtst point me to em :D
great write up! just took mine off and cleaned it out, haven't started the car yet as im waiting 2 replace the fuel pump this afternoon, but i can imagine its goin 2 fix my idle problems! thanx alot for this.
When I took mine off for the clean I took the idle adjust screw all the way out. Around it was a rubber sleeve. Now whenever I try to screw it back in the sleeve just rolls up the screw and I'm concerend that air may leak in through any gaps.
Anyone got any suggestions on how to get this rubber to seat on the screw inside the thread again??
Also the sticker under my bonnet says I should be setting the idle to 650rpm. Does anyone really run their car this low?
Edited by space_monkey
can you not just carefully screw it in and use a very small screwdriver to help persuade the idle screw rubber sheath back in? Mine went in without any hassles but I did have to play carefully with the rubber sheath when putting it back in :/
mine is idling between 650 and 700rpm but I heard the 33gtst's are meant to idle as low as 600rpm - I think ppl increase the idle point a little simply because its so low it doesn't take much dipping below that point for the car to stall.
Thanks Anthony. I'll give that a go after I pick up some small screwdrivers.
I can't seem to get my car to idle below 750rpm no matter how far in I turn the idle adjust screw. When I try to set the base timing to 15 deg by disabling the variable timing that the computer is running, the revs jump up to around 850-900rpm. I set it to 15 deg and then re-enable the variable timing. Straight away the revs drop to 750rpm and the timing drops to 0 deg. Almost like it's trying to get to 650rpm by retarding the timing when idling. It's a pain and I can't get my head around it. :/
  • Like 1
    • This is the clearest explanation out of those: Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension. Basically you turn the engine with the tensioner bolt loose, then use the allen key to hold it while you torque it up. And yes after that a good guide is being able to twist it 90o in one of the long free lengths of the belt
    • good choice....I have a set of those and use them all the time including on this job. Plus, no-one wants a damaged nipple
    • Thanks all, went with nismo strengthened belt and all genuine nissan idler and tensioner Question on RB25DET Neo Timing Tensioner: I have a question about the RB25DET Neo timing tensioner. In one of the videos (minute 20 of https://www.youtube.com/watch?v=17y37BB9xnA and minute 27 of https://www.youtube.com/watch?v=Pb99s2E9xUg), the process suggests tightening the tensioner pulley installation bolt to the specified torque initially, and then loosening it slightly to allow the spring to set the correct tension. Is this the correct approach? The R33 workshop manual on page 74 states: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. The way this is written is confusing. Does this mean: Undo the nut, then reduce the tension by turning clockwise? Snug the nut so it stays in position without applying tension to the belt while removing the timing belt? The manual wording makes it sound like the nut will tighten automatically when you turn the tensioner clockwise , which is unclear to me.   Timing Belt Tension Adjustment Process: After loosening the tensioner nut, you turn the engine two full rotations by hand, which should set the correct tension. Once the tension is set, you tighten the bolt to 43 N·m (4.4 kg·m). Before tightening, you need to insert the Allen key into the hexagonal hole to hold the pulley in place while tightening the bolt. In one of the videos, it’s mentioned that you should twist the belt side to side, or turn it slightly to check if the tension is correct. The belt should turn halfway, indicating the right tension. However, I know that twisting or turning the belt is not a good idea. What are your thoughts on this? Finally, how can I ensure the belt isn’t overtightened? I’ve seen many cases where people have overtightened the timing belt.   Manual Excerpts: Page 74: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. Remove the timing belt from each pulley. Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension.
    • Takes a few minutes to malke one. Wood, or steel, or a wrap strap with some strategically placed solids to provide teh drive onto the ribs.
