i have a rb20e engine in my cefiro it is working good for now, i was changing the o-ring on the injectors (as it was leaking) and in the process one of the injectors fell and cracked. Now it is proving real difficult to get one to replace it. what i want to know is:
1) Would the rb20de injectors work on the rb20e engine, they look like the same but would i run into problems with the air/fuel mixture as i assume that the rb20de incector would be more cc than the rb20e injector or is the difference small and would not make much of a difference.
2) my engine is stock however i plan to put in a performance coil. plug wires and some good plugs, pod filter and 3inch exhaust. so would the higher flowing injector be applicable to the following mods or would the stock one work just as good
dont worry this is just for the short term untill i put in a rb25det
Thanks
https://www.sau.com.au/forums/topic/110442-rb20e-injectors/
  • 5 months later...
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
