1st Vid - Camera stuck all over the outside of the car
http://www.cruisewank.com/ianhvideo02.wmv - 20Mb
2nd Vid - Filmed from a mates 500hp Supra
http://www.r34gtt.net/video03.wmv
awesome videos mate, any plans for the immediate or distant future?
thirty four: - your car looks mad! such an awesome colour, love TV2.
just noticed that the rear lights of your cars (thirty four and Ian) have the GTR white and red reversing lights in the rear bumper. Is that a SII R34 thing?
oh and nice vids! :yes: car sounds great!
oh and nice vids! :( car sounds great!
mine is only a series1 (built in march 2000) so that isnt it, im guessing either zappn's theory is correct or the previous owner did the conversion
SS8 Gohan - In the UK you need to add a Red Fog Light and thats where most people add it. It came with 2 white reverse lights as standard.
Thirty Four - I'm looking to add GT-SS/2530/Steel Standard turbos etc and a twin plate for 500-550hp (running 450hp now) but I may sell it soon anyway as I'm looking for a house (UK prices are about AUS$600,000 for a 2/3 bedroom house where I work! - it's cheaper up north but not by much). After that I'm thinking of a 260rs Stagea running 550-600hp.
Foznice - It's on a switch which, when turned on, has the spark permenantly on via a coil. You need to hit high revs then take your foot off the accelerator to let the revs die slowly (this gets the flame going) then after a few secs give the throttle a quick blip to stop the flame.
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
