hi im just finished rebuilding my engine and am at the stage where i need the torque specs for completion.
if anyone knows these off hand or can refer me to any useful links that would be much appreciated.
thank you.
engine is rb25det.
torque specs needed are for the head and bottom end.
https://www.sau.com.au/forums/topic/110447-torque-specs-for-rb25det/
  • 2 years later...
No, Nissan is not helping.
I'm having this problem too.
Someone has to know please.
Head bolt specs are 1/ tighten to 29 Nm
2/ tighten to 98Nm
3/ loosen to 0Nm
4/ tighten to 25-24Nm
5/ tighten to 93-103Nm
Someone please come up with the Big and Main torqe specs...
these are some results you can try, but the engine man is at the bottom of the page, follow the link go to r33 eng its on page
GI 12.
1. I've been told the head is torqued down in 5 stages.
1. 22ftlbs
2. 72ftlbs
3. slacken off
4. 22ftlbs
5. 75ftlbs if using ARP Moly lube or 85 if using oil
2. After searching I came up with 34-43.5ftlbs for the mains and 10.3 to 11.8ftlbs for the rods (plus 60 degrees)
The mains seem like they have a very wide range
http://www.nicoclub.com/FSM/rb/
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
