dunno bout common faults but on mine ive
replaced all hoses/pipes in engine bay as they were perishing (including fuel pipes also)
including powerstreering pipes
new startermotor (old one totally wore its bushes)
shreads tyres due to suspension being haddit (would always wear off the inside ring of the tyres, regardless of how many balances/alignments i got done (new coil overs fixed it)
new steering column switch
fixed solder on power windows
new thermo fan (old one cracked)
new o2 sensor (to try and fix fuel economy, still attrocious)
new clutch
new plugs
new battery
i believe i have got off pretty lightly
Edited by Spook's_Skyline
https://www.sau.com.au/forums/topic/110448-r33-gts-t/#findComment-2034818
I've had my
Radiator - replaced with new
Fan Clutch - replaced with new
Coil Packs - replaced with 2nd hand (twice)
Battery - replaced with new
Water Pump - replaced with new
Timing belt (did it with water pump) - replaced with new
Nothing too much really - usual wear and tear parts I would say - except for the coil packs!
https://www.sau.com.au/forums/topic/110448-r33-gts-t/#findComment-2035194
Ive had mine for over a year now....
I have replaced:
- Spark Plugs
- Brakes
- Tyres
Just the things you would do on a normal family car, so i havnt had any troubles (touch wood).
Things that need changing in the next 6 Months:
- Clutch
- Timing Belt
- Water Pump
So all in all ive gotten off alright.
I guess it just depends if you buy a clean car or a worn out car....
https://www.sau.com.au/forums/topic/110448-r33-gts-t/#findComment-2035382
I've had my car for going on 4 years now and all I've had to change on it were brakes, spark plugs, timing belt and tyres (plus regular servicing of course!)
The only thing that has gone wrong with it so far is that the electric side mirrors don't work anymore but that's an easy fix if I could be bothered.
https://www.sau.com.au/forums/topic/110448-r33-gts-t/#findComment-2035528
