  • Replies 106
Posted Images
Gotta replace my afm and a couple of coils, nothing major.
My mechanic quoted me $500 to replace my afm, i was like 'what the....?'
That's ridiculous i am changing mechanics! Had it serviced 4 weeks ago, they changed a couple of o-rings in the gearbox and now it leaks even more. They replaced a headlight globe, then didn't re-adjust the beam. its only small things i know but if you do a job right, then do a job right!
Yeah i have heard good things about Boost Worx and Graham West, will have to try there next time!
Thanks Guys
Give boostworx a try, they're currently doing all of my wiring, etc - and I'm very impressed with shauns attitude and work ethic. :happy: Their pricing seems very reasonable compared to some of the so called other "performance workshops" in adelaide.
Are you replacing the AFM with an item you are supplying, or was the workshop going to supply the afm in that quoted price?
No they were supplying the afm, 2nd hand original or new after-market, still they go for 250-300. I got 2nd hand from Adelaide Jap Dismantlers $195. After market = $290 new. Thats at least $200 labour for changing the plug! I can almost get a lock-bar for that.
well Adam, if you need to use my AFM for a while longer, then thats no probs mate.....!
start searching the for sale thread I reckon!
or make me an offer for it - I guess I wont need it in the future!
sent you a pm.
Edited by Tangles
I go to John Keen at Hi-tech Dyno Tune on south road.
No complaints.
yeah went there to get my boost controller fitted and dyno tuned, great service but does he do mechanical stuff too or just tunes and mods?
Definatly give Shaun a call @ Boostworx, He fitted my Z32 and fuel pump, cant quite remember how much but i think it was about $80-100 for the AFM fitted, then about the same for Fuel Pump.
Graham West and John Keen @ Hi tech is also good so i've heard. He is one of 3 brothers Bill @ ATS and the other brother is Turbo Tune(where John used to work) but havn't heard to many good things about TT!
Im in the middle of getting a heap of Whiteline suspension goodies for my Stagea.
Received today the front and rear fully adjustable 24mm thick swaybars, and the front castor kit.
Im also going to order a sub-frame alignment kit and the full front and rear Bilstein shocks (using standard springs, with no camber change), probably after next fridays payday.
Going to ask around places for how much for install (I could do the swaybars but probably not the rest).
Anyone have any suggestions?
My first point of call will be Pedders at Morphett vale (near my house) - has anyone got some suspension places they'd recommend to install some of these parts?
Cheers in advance.
Brendan
Edited by Tangles
Been taking my car down to Scott at AVS Suspension on south road.
He and his old man run the shop; friendly bunch and pretty good prices.
http://www.avs-suspension.com.au/
another vote to Shaun @ Boostworx
Brendan:
i got a friend who used to work in ASE, he now has his own business which is a mobile workshop (van)
he did my s15's suspension, don't think any workshop can match his price
His name is Ryan and u can contact him @ 0433 149 727
Edited by Maxx
went in to graham west today and have to get outer drive shaft joints, all pivot bushes flexing, poly camber kits and rear cradle bushes slightly soft, anyone know where i can get all these cheaper maybe?
Maybe try sending a PM to Sydneykid - ie supply you with Whiteline goodies?
he able to send them over cheap? quoted approx 500-650 for both outer drive shaft joints to be disassembled and fitted???? cant get any cheaper elsewhere anyone know of? might aswell get all done at once while is up there.
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
