  • Replies 106
Posted Images
can get hold of a standard turbo, is it possible to bolt straight on or would i need to take to turbo place to get fitted? looking for cheapest way out right now as getting bigger turbo would cost me heaps to repair everything else
@ richmond u have Steve from Manta Racing (Manta Automotive Services)
hes a top bloke and wont steer you wrong and he knows his stuff when it comes to GTR's and skylines
he replaced my whole front diff without taking the engine out and keeping the cost to a minimum and he warranties his work (labour) for 12months
I'd suggest taking it to Bill Keen at ATS on Marion Rd to get Hi Flowed, May as well while it's off the car........and you will get more power than just leaving it standard and won't have to spend 1-2.5k on a aftermaket turbo as soon or if at all. He will prob be able to fit it for you also.......Otherwise as always take it to Shaun(Boostworx) :D
Darren
Darren i was impreswsed with Boostworx, they haven't sorted out the problem with the pinging yet but are getting some more stuff (ecu ect.) to try. They checked all the timing, mixtures and the standard ecu and it didn't come up with anything. Turns out my "standard" skyline has a few after market bits like the oxyen sensor which may be causing the problems.
Starting to think i might sell this 33 and save up for a GTR
^^^^^^ Yeh sweet Nick nice work, Shaun and the boys have work on a few cars of my mates now(white Evo3, pink Rx7 ATM and heaps of people's on here) and i i hear is good stuff from him!
GTR hey, You could hook up with Shan(funkymonkey) on here who is J Spec, I spoke to him about 33 GTR's when he was here and was rolling off some very good prices for them, maybe keep that in mind!
yeah i saw the pink RX7 and the EVO in there. It's alos good for me being just around the corner from work, had to get a manager to drop me off to pic it up this arvo.
I just hope they can sort out the problems with the timing as it is really annoying me especially now i have to miss out on another cruise
Ummm, maybe a SITC might help? Have a look into it..... SK's thread http://www.skylinesaustralia.com/forums/in...c=80642&hl=SITC
I dont really know, but I use a Apexi Super-ITC, ie an Ignition Timing Converter. Mainly 'cause I run auto, but also it links well with the SAFCII, both being Apex etc. ~$220 USD on ebay, generally $300aus delivered, 2nd hand........ I managed to snare a new one there for $20 less, but around $300 is the go.
Can adjust a fair bit of timing into 5 rpm spots, not saying it will help your particular timing issue but definately an excellent tuning tool (with my sitc/safc/ebc & mods I expect ~210Awkw with a 500hp turbo)
Edited by Tangles
oh u made a comment in the thread i posted when i needed my diff done i thought u had urs done once too
if u get a 200+ AWK combo happening i suggest u look into GTR crown and pinion gears otherwise ull do wot i did and strip ur gears
Edited by Madaz
i dont know this is wot ive been told by a very good mechanic that the R33 GTS-4 DIDNT come with turbo and had a ratio of 3.4 and has too much power and torque for the drive ratio :S
R32 GTS-4 (RB20DET) came with 3.6 and all GTR's came 4.11
Ive always had the impression the R32 GTS4's have always had the 4.363:1 diff ratio.
http://www.skylineowners.com/forum/showthr...goto=nextnewest
There's a little thread also.
I'd hate to drive the RB20DET GTS4 if it really did have a 3.6:1. :nyaanyaa:
  • 5 weeks later...
not happy with boostworx now. rang them this week to fid out what was going on with my car. They started out reassuring me that it was a detonation problem, then they were trying to tell me I had a series 2, when i have a series 1.
Had one of the mechanics at work who had a 33 GTST and he said either the turbo or exhaust manifold (which is also what cubes suggested) had a look today and the one of exhaust manifold studs has broken off (can't tell if any of the other ones are).
Any know where I can get this fixed and roughly how much it would cost?
I was thinking about going to Adelaide turbo services on marion road this week and getting a quote from them
Edited by Whiplash
Out of curiosity.. Which stud went? I've seen a few rb's where the cyl one and two studs go before the rest.
Was it shaun u spoke to at Boostworx or the new bloke I saw there a week or so ago?
I've been talking to shaun the entire time i have been dealing with them. Was disapointed with it as I was happy when I got my car serviced there, after all the good stuff I've heard about them in this thread
the one closest to the firewall. The other end was loose but we didn't want to tighten it up incase it broke off aswell
The mechanic that helped me this morning said he would take it to work and it would take a few days to repair and will cost a bit as the manifold usually need machining to make it flush again if the studs have been broken for a while, which looks like the case here.
I'd hate to drive the RB20DET GTS4 if it really did have a 3.6:1. :O
well all i know is pete from willal racing sent a R32 ratio over to steve @ manta racing and steve said the ratio was 3.6 and we wanted 3.4
When I pulled the old motor out I was suprised there wasn't any noise as the first and rear cylinder had broken exhaust studs, 4 studs broken in total.
I didn't bother machining the exhaust manifold and its been fine for 40,000km's, I've been watching the block for any black crap. :O
Apart from that its not hard to do, I can have a turbo pulled off within 1.5hrs, takes about the same to put it back on. To remove the studs stuck in the head was suprsingly easy. Some may not be so lucky though. ;)
Its important to torque the exh. manifold nuts up to specs as if you don't you will break more studs.
Its scary how loose the torque specs are, it felt like only just past finger tight. :D
Bl4ck32 when doing his also commented on the lack of torque required.
So is it possible to do it at home or am i better off paying a workshop to do it?
The machanic i had around works out at Agastino Mitsubishi and said that it usually takes a couple of days to drill out the stuck studs and replace them
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
