Hey Guys
I have a GTS-T Skyline, With and ARC intercooler, full exhaust BOV and After market adujstableSupspension (supposed to be worth $3000) I also suspect the car has cams and an Aftermarket computer but havn't had a chance to have a look as I just bought it.
I have stock wheels, When I take off ON A STRAIGHT LINE and put my foot down car has tranction however when I change into Second the car is almost side ways (which is quite fun but it just seems too easy for the car to loose traction)
Is there anything I can do to avoid this from occuring (besides taking my foot off the pedal),
Sorry if im asking dumb questions, this is the first turbo I have had but have driven a few previously and none have done that Esp on a straight line, could this be because of the power of the skyline ?? or the suspension ?? any feedback would be great.
Thanks
https://www.sau.com.au/forums/topic/110486-traction/
I would suggest that your suspension is very firm and/or your tyres are not so good. check if they are damper adjustable, but even then if your suspension is adjustable and your tyres are no good you will not get good traction...so invest in some good rubber
Edited by marchGTR
https://www.sau.com.au/forums/topic/110486-traction/#findComment-2035456
If runnin stock boost then 7psi at max...
heheh i got the same problem, around corners.. the back just kicks out like crazy!!
i say buy new rims, with atleast 9inch wide on the rears..
the 16s with 205s are just awful!!
why didnt nissan give us stock 17s or or just wider width..
https://www.sau.com.au/forums/topic/110486-traction/#findComment-2035966
Im not worried about the corners as that is excepted, its when im on a straight line, i put my foot down changed and 5 1/2 grand and as soon as i punched second the ass came out to the right. Its as if it was raining but it was dry as.
it could be the tyres as the car was sitting for a year and a half, without being driven so maybe the tyres got hard or something ..???
https://www.sau.com.au/forums/topic/110486-traction/#findComment-2036021
How about you stop "punching second" and bring the clutch up a little slower (or engaging the throttle a little slower) once you've selected second? What's wrong with backing off the throttle when you change gear, like you're meant to?
You're more likely to light up your tyres in first gear than second. Its simple physics. If you've got traction in first gear, then its not (in itself) a tyre / suspension problem. Its sounding more like the problem is you.
Aside from that, run a set of super soft tyres with low air pressure and dial your rear dampers as softly as possible. Check your wheel alignment. Turn down the power.
https://www.sau.com.au/forums/topic/110486-traction/#findComment-2046346
his right, i can choose to loose traction in first or not, but in the end im still doing the same speed
https://www.sau.com.au/forums/topic/110486-traction/#findComment-2046980
    • And half of them have been converted to turbos.
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
