Hey Guys
I have a GTS-T Skyline, With and ARC intercooler, full exhaust BOV and After market adujstableSupspension (supposed to be worth $3000) I also suspect the car has cams and an Aftermarket computer but havn't had a chance to have a look as I just bought it.
I have stock wheels, When I take off ON A STRAIGHT LINE and put my foot down car has tranction however when I change into Second the car is almost side ways (which is quite fun but it just seems too easy for the car to loose traction)
Is there anything I can do to avoid this from occuring (besides taking my foot off the pedal),
Sorry if im asking dumb questions, this is the first turbo I have had but have driven a few previously and none have done that Esp on a straight line, could this be because of the power of the skyline ?? or the suspension ?? any feedback would be great.
Thanks
https://www.sau.com.au/forums/topic/110486-traction/
I would suggest that your suspension is very firm and/or your tyres are not so good. check if they are damper adjustable, but even then if your suspension is adjustable and your tyres are no good you will not get good traction...so invest in some good rubber
Edited by marchGTR
https://www.sau.com.au/forums/topic/110486-traction/#findComment-2035456
If runnin stock boost then 7psi at max...
heheh i got the same problem, around corners.. the back just kicks out like crazy!!
i say buy new rims, with atleast 9inch wide on the rears..
the 16s with 205s are just awful!!
why didnt nissan give us stock 17s or or just wider width..
https://www.sau.com.au/forums/topic/110486-traction/#findComment-2035966
Im not worried about the corners as that is excepted, its when im on a straight line, i put my foot down changed and 5 1/2 grand and as soon as i punched second the ass came out to the right. Its as if it was raining but it was dry as.
it could be the tyres as the car was sitting for a year and a half, without being driven so maybe the tyres got hard or something ..???
https://www.sau.com.au/forums/topic/110486-traction/#findComment-2036021
How about you stop "punching second" and bring the clutch up a little slower (or engaging the throttle a little slower) once you've selected second? What's wrong with backing off the throttle when you change gear, like you're meant to?
You're more likely to light up your tyres in first gear than second. Its simple physics. If you've got traction in first gear, then its not (in itself) a tyre / suspension problem. Its sounding more like the problem is you.
Aside from that, run a set of super soft tyres with low air pressure and dial your rear dampers as softly as possible. Check your wheel alignment. Turn down the power.
https://www.sau.com.au/forums/topic/110486-traction/#findComment-2046346
his right, i can choose to loose traction in first or not, but in the end im still doing the same speed
https://www.sau.com.au/forums/topic/110486-traction/#findComment-2046980
    • You could have a chat to these guys and empty your bank account, I like their de-stroked 2.5 combo. https://esslingeracing.com/mazda-4-v-per-cylinder-4-cyl-engines/mzr-2-5l
    • Listening to pearl jams best of. Used to dislike them, but have grown into it.
    • Sorry I'm late to this, but if you're still looking or for others who happen upon this, pretty sure these are what you're(and I'm) after.....   https://www.kmakaero.com.au/r32-skyline-gtr-rear-spats-for-gtr   https://www.obsessionr.com/products/muse-japan-bnr32-n1-type-rear-spat-set   I'm personally interested in the Muse set, as they are also made out of ABS instead of fibreglass.
    • El paso girl is a bloody good meme. But really, NoS.
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
