forgot to mention I have 1994 R33 GTS4,
One thing I noticed is once the 4WD and ABS led flashes the SLIP led doesnt work anymore, normally it flashes when the rear wheels loos control or slips. which means it has switched back to RWD from 4WD.mmmmmmm, No I dont know why ABS led allways cometogether with 4WD??????
Maybe a electrical problem.................. :):):mad:
Sounds like you rear ABS sensor/s are faulty or damaged.
Both ABS and ATTESSA systems use the ABS sensors to determine slip/skiding/etc.
I took my car to a workshop, which they hook it up to a handheld computer thingy, it came up saying "G sensor error"
By the way where is the ABS sensor can be found on ? im sure all 4 wheels got them but no idea what it looks like or where it is exactly located in?
any help...................a pictur maybe...
Cheers
The G sensor is a small metal box in the centre console rear of the gearshift. You will see it as soon as you take the console off.
It has a small window on the front which apparently goes red when the sensor is busted - don't forget your problem could be the wiring between the sensor and the computer as well
The ABS sensors are little toothed wheels - front ones are on the hubs and rear ones are next to the diff. There is a small sensor attached to the diff or hub that reads how many teeth go by to calculate wheel speed.
Cheers, Thanks mate. bythe way i found more infor regarding this issue on another web site as well.
http://www.gtr.co.uk/forum/upload/46982-ca...my-gtr33-2.html
FYI----(The following has been copied from above mentioned site)
If you disconnected the battery you may of just deleted all the fault codes from the ECU,s that have recorded the faults.
Over the last few years we have come to notice what causes these faults and mostly are as follows in order which we have noticed.
A 33 has Electric Hicas so the Power steering fluid fix will not work ( the 32 is the only car that has hyraulic Hicas )
Normally if the 4wd lights comes on by itself it will be a low fluid level.
If the 4wd lights and ABS lights come on it will be throttle switch or ABS sensor.
If the 4wd/ABS/HICAS lights come on normally the rear wiper pipe broken and it has flooded the ECU,s in the boot.
Cheers
Chinthana
  • 3 weeks later...
what exactly is the throttle switch?
having just messed around with the throttle getting wiring through the fire wall my 4wd + ABS lights have come on. Guessing its related.
Cheers
Chinthana
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
