As I understand it, the PowerFC is simply plug and tune. You plug it into the existing wiring harness and then start tuning. Even from a layman's perspective that seems much easier to install. And if its got the facilities and potential to back it up and not much else is more highly regarded, then its all about who you go to and what they specialise in. Each to their own and what they're happy with, and the tuners who can get the most out of them.
  • 3 months later...
  • Replies 49
Let me get this straight!
Apexi make 2 FC models??
A Djetro, wich uses the map sensor and the "normal" FC that uses the damnd AFM!?
Is there any price diffrence between the two? Can the APexi dJetro run without a AFM at all?
cheers,
trev
Originally posted by Sydneykid
Hi ed, I prefer AFM's, much more accurate, but you can get a Djetro if you want MAP.
Originally posted by Jet
piggybag stuff could cost more in the long run.
Why's that? I got an S-AFC tuned last year (installed myself) for $150. A few months ago I got a new FMIC and plenum installed, and I'm running off the same S-AFC tune. While not perfect, it's still more than adequate and my mechanic said that it wouldn't be worth re-tuning it for these mods. He said that once the Bosch fuel pump goes in, it'll be time to re-tune it.
but SAFC isnt a plug&play computer.
it is classified as a piggybag. SAFC could have less functions if you compare it to unichip. and that probably why it costs alot more to tune a unichip.
I will need to get my car retuned next week. each time it costs me $550. work that out.
I know that it's not plug & play, where did you get the impression that I thought it was? For what it is, it's a dirt cheap performance addon that doesn't need re-tuning for every single thing that you do to the car.
I'm not even sure that you will need the Uni-chip re-done for every minor mod you do to the car, are you sure that it's not just your mechanic trying to wring more dollars out of you? $550 is a hell of a lot of cash to put up for every upgrade you do, no matter how minor.
since the last time my car was tuned.
I got 3'inch turbo back and highlow cat, FMIC installed.
I didnt feel any difference at all after I install all those stuff.
I just assume its time for a retune.
Something wrong there dude, I noticed a huge difference from the exhaust, and when the FMIC went on, my car just fryed the clutch.
Hey guys, I'm looking at up grading my cars ECU and I have a question about you guys with aftermarket ECU's or piggy back computers.
How do you find your car? is it smoother nicer to drive? I would like to know what people think of their car with a e-manage or Power FC in it?
Do stand alone computers such as the Power FC run under closed loop conditions and do they still run thing which aren't performance related, like air con e.t.c...
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
