  • Replies 69
I think its going to come down to a personal choice for most people... I would say VL ... but I am biased owning 2 of them before moving up to a skyline....
again its personal preference, but I like the style of the VL a bit more then the DR30 which makes my choice easy...
https://www.sau.com.au/forums/topic/110521-vl-or-dr30/#findComment-2036162
I've got a DR30, as much as i love driving the thing, its a pain for getting parts, heaps expensive when you do find things, so unless you've got a budget behind you, and are not willing to trash shit outta them and crash them you'll be right...
If its your first car, prolly go the VL, just due to ease of parts...
So glad i've got my dr though and will never sell her :laugh:
https://www.sau.com.au/forums/topic/110521-vl-or-dr30/#findComment-2038372
or what wldcrd said, cause the first one gets trashed anyway. We all say we wont wreck it but im yet to see anyone not.
Little bro wanted to copy me and get a 33 for his first car but wisely listioned to me and got a laser. That laser was sold to the wreckers a few months back for $100!
https://www.sau.com.au/forums/topic/110521-vl-or-dr30/#findComment-2051615
not bad not bad. Are they are lighter/heavier car then say a 32 or 33?
Should get a vh and put a 'and justice for all sticker' on the back window. Play pantera really load drive really recklessly and yell out the window and death stare people at the lights. And have countless amounts of empty beer bottles on the floor and f**k it might as well drive pissed aswell! hahahhaahaha
https://www.sau.com.au/forums/topic/110521-vl-or-dr30/#findComment-2057753
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
