2006 Sau Competition #1!
PranK
 Share
Hi All,
Ok, time for our first proper computer art competition!
SAU, along with Kudos Motorsports have initiated a few competitions for SAU members. The first of which is the following;
Design a new SAU Banner!
  • The banner will be for the dark style - Click here to change to the Dark Style
  • The banner will need to be within these dimensions: No higher than 100px and No wider than 820px.
  • The banner will replace the current banner.
Rules
  • Each member can only submit 1 entry.
  • The entry is to be uploaded to this Gallery Category - here
  • Once your submission is made, you cannot edit or replace it.
  • The winner will be chosen by public vote.
  • Admins and Moderators are able to enter also due to the public vote
  • Images are not to contain nudity or anything that may be deemed offensive (Contenders will be withdrawn and warned if this rule is breached)
  • Submissions need to be in by 5pm EST 21/04/06
  • The poll will be created the same evening and the winner decided by winning votes as at 5pm EST 30/04/06
Prize
The winner will receive from Kudos Motorsports one of the following (of the winners choice);
  • Nismo gear knob
  • Nismo side indicators
  • Set of NGK Iridium spark plugs
  • $40 voucher
Get Photoshopping!
  • Replies 49
im having a go atm.. well wait for a wile incase i come up with other ideas for it to add :(
hopfuly it'll turn out good, wouldnt mind a set of indicators ya know lol
would prefer a filesize under 50kb to keep page sizes to a minimum (current banner is 24kb). preferably not flash, as it adds more complexity to the pages (having to download the correct plugins etc, annoying mouseover sounds and transitions). so static jpg or gif would be ideal. But feel free to submit a flash banner if you can make one.
how the hell do you change back from dark style to the normal, white backed screen. the inverted colours are giving me a headache
EDIT
never mind, i have just figured it out, literally as i finished typing this message
Edited by foamer_69
spewing we can only be limited to one.... i dont see the point in that, its not like its exactly cheating.... !?
Why?
Mr A is a novice and takes 5 hours to submit a banner but at this length of time simply cant submit any more.
Mr B is a pro and does 5 in an hour, which he submits and now has a 5x shot of winning over Mr A.
Just one of many scenarios.
C
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
