  • Replies 49
Here's mine, I've designed it so it integrates and flows with the forum's banner background (ie: you can't see an edge on the left or right of the banner) and since we love to use the site multiple times a day I've made it subtle so that it's not in your face each time:
Edited by justinfox
winner!
Im no photoshopper, but maybe as well as a new banner you could get people to post up the best 3 pictures of THEIR car.
The moderators could all huddle together and pick out a certain number, and get the pictures to rotate at random next to the banner?
Just an idea. Im sure many people would appreicate seeing a photo of all their hard work.
Nice one JustinFox!!
This was going to be mine till I realised its a one plus MB filesize!!
Damned if I kow why with so little colours.
looks nice man
the reason its so large is because of its area and also the amount of frames it consists of =)
