Hey everyone, hopefully someone will be able to help me out or at least steer me in the right direction.
I have a 1989 R32 GTS-T automatic RB20DET and i am in desperate need of a rear window, window was smashed in Sep 05' and still haven't managed to find a replacement. Genuine replacement windscreen from japan will cost approx $1,300 (thats a full on last resort)
Just to settle a bit of a score with the wreckers, will a rear window from any R32 2 door fit onto my car? As i told the bloke that it was a 1989 R32 GTS-T 2 door and he assured me that he cut the windscreen out of a rear cut R32 with his own hands, so either he didn't cut it out himself or he dosen't know what an R32 GTS-T looks like. . . or i am wrong and there is different windscreens for different R32's
When the windscreen eventually got here it wasn't even close to fitting, im talking 2-3 inches short (top to bottom) and approx 1 inch too long (side to side), possibly off an R33.
If anyone has a spare or knows where i can find a 2nd hand one for around $400 please get in contact with me as it's been too long and cops are threatening to defect me. Plus my parcel shelf is totally screwed due to rain and the elements.
Also after a 5spd gearbox, RB25 box would be good but i hear there pretty rare as there quite good, so an RB20 gearbox will be fine. If anyone knows a good place to purchase one or has one they are looking to sell please post a reply or get in contact with me.
Thanks for you time
Sam Healy
https://www.sau.com.au/forums/topic/110554-rear-window-and-manual-gearbox/
Thanks for you time
dude have 1 i syd at my house but interstate is such a pain do u have relos in syd??
Sam Healy
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
