Hey guys,
Just wondering how much you think second hand Trust suspension is worth? I will try to get some photos up tomorrow.
Heres a few details:
Came off a 1991 32 GTR.
Light blue in colour with darker blue springs.
Black knob with 1 - 8 on it (as you can tell im not a suspension know it all).
Appears to be no leaks.
They have the letters KYB and 2GI0.
I know the info is a little vag. but any help would be appreciated.
Cheers.
post-23674-1143001627.jpgpost-23674-1143001641.jpgpost-23674-1143001662.jpgpost-23674-1143001695.jpgpost-23674-1143001706.jpgpost-1777-1125302755.jpg
Edited by Extacy
https://www.sau.com.au/forums/topic/110562-looking-for-some-answers/
KYB 2G is obviously the brand KYB by all accounts
AGX is the form you are describing with 8 way adjustable dial.. far too soft to be useful on lowest setting... decent at middle and you'll pretty much be driving around with it dialed in as hard as possible.
not sure where trust comes into it ... obviously with the info provided its a little unclear on all the bits.
KYB 2g AGX are used in some skylines but fairly rare so some pics would be great so verify my "beliefs" here.
if these are indeed what i suspect normal cost is around 230 a corner.
Danz
Edited by Danz-
KYB sell their shocks to all sorts of people who stick their own brand on them. Look for oil and gas leaks, compress fully and check the damping still works and that there is gas pressure. Shake and listen for rattles. KYB's are notorious for leaking and then falling apart internally.
:( Cheers :)
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
