Hey,
I pulled down two rb25 det blocks...one for a rb30 build and the other just for a light rebuild for the race car while the 25/30 is in progress. I have some photos of the blocks to confirm about oil restrictors. One block is a s1 and other is s2. I had a piece of 1.56mm m/s tig electrode and i could not fit it down either of the two oil feeds. Both of these motors were dead std when we got them...one from car we already owned and one I picked up from down the coast which came in dead std form 2nd hand. Now If the restrictors are 2.4mm then shouldnt i have been able to fit the electrode down the feed? To me they look about 1.5mm, after i tapered the electrode tip abit it would just fit into the feed. Verniers verified 1.5mm holes.
Remember everything on these engines is std..internals/externals. So im lost.
Or am i confused with whats what here?
Cheers.
https://www.sau.com.au/forums/topic/110572-rb25det-block-oil-restrictors/
will watch this thread ..
but on the tomei web site they sell the restrictors, and only thing they say about the rb25 is that you shouldn't use them if still using lash (hydrolic) lifters..
interesting..
was looking at my rb30 and rb25 blocks. i thought the rb30 ones were bigger than the rb25 (visually only)
Im pretty sure i read somewhere 2 X 2.4mm hole std for rb20 and 25. Im pretty damn sure these engines are both std and have 1.5mm holes in them.
Yeh i know the tomei site doesnt recommend using them with the hydraulic followers...but SK recommendations have been noted in the rb30 thread regarding oil restrictors.
Has anyone else opened up a 20/25 to find 1.5mm holes in their feeds?
Bloudy Cubes hey lol...leading us all astray. Unless he just got told that from his engine builder and someone got confused somewhere along the way.
So i guess you would still just block one off as per SK specs.
Edited by r33_racer
was the Rb30 block using a 1.8mm restrictor as per his measurements?
this is something i have been tossing up over the build, still cant get a good answer on what to run.. might just run an N1 with 1 feed of 1.5mm...
options options options
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
