Northern Suburbs Monthly "breakfast Of Champions" Meet
  • Replies 42
Was good once we found it, There was three skylines and a stagea cruising around looking for it, We all saw each other and sort of followed.
We randomly ran into geoff and from there it was all good.
haha I can so picture you monkeys driving around and around all those roundabouts following each other. Shoulda told everyone to look for the midnight purple R33 GTR which'll be parked outside the venue.
Hopefully those that went liked it enough to come back on the first sunday of next month.
Sunday in Adelaide... was... eventful :) although we ordered breakfast in bed and I was thinkin I'd rather have the food at the Lakes.
  • 4 weeks later...
  • 5 weeks later...
Who's up folks?
Well I am anyway so the same place. The Lakes Cafe, The Lakes Boulevard, Mill Park Lakes, South Morang.
Hope to see a few friendly faces for breakfast at about 10am.
how's about this sunday then Geoff? I'll be taking out my gearbox at the workshop tomorrow night, so hopefully I'll have it all done by Sunday. Think it is the bearing that's seized.
I'm leaving on the 20th (tentative for now... might be as late as first week of July)... for now I'm moving to Parramatta where my parents live... but looking at buying my own place somewhere in the inner north shore.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
