Hi, my names Nic i currently own a show Swift GTi and purchasing a R33 series 1 in the next month or so. Always loved the skylines, big fan of your forum too very useful. just a quick question im looking to purchase this body kit:
I have been told that it might be the GTR front bar (not original of course) along with the 400R sides and rear but i just wanted to double check before i start calling and emailing around. any info would be great, and if there is a forum sponser that does these kits that would be great too!
Many thanks, look forward to cruising with youse real soon.
:laugh:
https://www.sau.com.au/forums/topic/110616-hello-quick-question-about-the-r33/
cheers guys. the rims look good but i already have another design in mind. im assuming this bodykit then is the same? yeh i found that car on carsales, looks really good but the kms are a lil high :thanks:
Baby Blue Skyline 01
Baby Blue Skyline 02
im just a lil confused cause the sides look different and the frontbar doesn't have those nostrals on the front of the kit. sorry to be a pain, if theres a suzuki question ill answer it no problems, im just new to nissan.
Hey Nic.....front bar on the blue one would be a copy (?) of an early R33 GTR front bar....the N1 vents were only added on the series 2 (I think) and definitly the series 3 GTR.
Side skirts are diff....the 400r ones have the little vents in them on the rear 1/4 section.
Hope that helps
sorry to sound like a bit of a n00b but would the blue skyline kit be available cause im seeing alot of you guys have similar kits but with those nostrals and urs also seem alot lower to the ground than this blue kit? also is that skyline a Series 2 skyline and would that kit only fit a Series 2? any info would be tops!
Pretty sure that blue skyline is a series 1. The bonnet on a s2 has much sharper ridges, also the headlights on a s2 are slightly thinner & sharper than a s1.
Can't say that I'm a fan of that bodykit on the blue skyline though. 400r skirts look much more tidy.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
