Based on the interest of those wanting leather gear knobs after the first group buy.....
i'm willing to organise this 2nd group buy for another round of them.
These Genuine Nismo Leather Gear Knobs will screw on to any of the follow gear sticks -
S13, S14 & S15 silvias,
180 & 200sx
R32, R33 & R34 (not 34 GTR though).
THESE ARE GENUINE NISMO LEATHER GEAR KNOBS
Exactly the same as the ones previously sold in the old group buy that was organised by nate33t
- http://www.skylinesaustralia.com/forums/in...howtopic=107029
Minimum order: 10.
Cost: $60.00 including postage.
Starting Date: 22nd March, 2006.
Ending Date: 12th April, 2006.
(Please note that this will cost an additional few $$'s as nate33t had the company/business he worked for, pay for the postage).
Please PM me with your details and I'll add you to the following list of those who have requested/ordered one.
1. r33skyliner (myself) - PAYMENT RECEIVED.
2. Ol_Mate - PAYMENT RECEIVED.
3. R3LOAD - PAYMENT RECEIVED.
4. Syphon - PAYMENT RECEIVED.
5. LANFOH - PAYMENT RECEIVED.
6. Sweet_Gtst - PAYMENT RECEIVED.
7. WRXSUX - PAYMENT NOT RECEIVED, TAKEN OFF THE LIST.
8. writeoff - PAYMENT RECEIVED.
9. beastien - PAYMENT RECEIVED.
10. livicuru - PAYMENT RECEIVED.
11. khunjeng - PAYMENT RECEIVED.
12. Al - PAYMENT RECEIVED.
13. SLVR32GTR - PAYMENT RECEIVED.
14. code blue - PAYMENT RECEIVED.
15. reflexman - PAYMENT RECEIVED.
16. SLYLINER - PAYMENT RECEIVED.
17. mufro - PAYMENT NOT RECEIVED, TAKEN OFF THE LIST.
18. jonjon - PAYMENT RECEIVED.
UPDATE
There is no more orders being taken now. I've taken more orders then initially planned.
All PM's have been sent out with payment details. All payments are to be made by Friday, 14th of April.
https://www.sau.com.au/forums/topic/110619-genuine-nismo-leather-gear-knob-2/
  • Replies 161
I'm keen only if the gear knob has an inner plastic sleeve with a 10mm thread that can be removed.
The reason for this is that I still have a Nismo gear knob I bought from a previous group buy that needs the inner sleeve.
I figure I could swap the sleeve between the two and use the leather one in summer when the black chrome one is too hot to handle.
Those that have express their interest, your names have been added to the list.
Sorry, these nismo gear knobs will be the exact same ones as previously sold.
I just reread the previous Group buy on these gear knobs.
You have one in your car already right?
When you get a chance can you check if the inner sleeve can be removed.
The sleeve needs to be 55mm high, have an outer diametre of 20mm, and an inner thread of 10mm. If it matches these dimensions it should fit the other gear knob I have. Then I definately want one!
Thanks.
These are a great buy people. Currently going for between $90 - $130 on ebay, and that's BEFORE postage. They look and feel amazing in real life too.
Sweet_Gtst, you've been added.
Payment details will be provided once we have a full list.
To save myself time in the sake of not getting a full list, it would be best for everyone to make payment once I have a full list of people there. If I dont get a full list, then there would be no need to refund the money.
AD GIVEN TO ME -
NISMO LEATHER SHIFT KNOB!
**BRAND NEW AND IN ORIGINAL PACKAGING!**
Suits R32 R33 and R34 Skylines, but also other Nissans with 10mm shift, as far as i know, thats most of them! Please double check your vehicle prior to bidding
(300ZX and 350Z's have 15mm so will not fit on them)
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
