Based on the interest of those wanting leather gear knobs after the first group buy.....
i'm willing to organise this 2nd group buy for another round of them.
These Genuine Nismo Leather Gear Knobs will screw on to any of the follow gear sticks -
S13, S14 & S15 silvias,
180 & 200sx
R32, R33 & R34 (not 34 GTR though).
THESE ARE GENUINE NISMO LEATHER GEAR KNOBS
Exactly the same as the ones previously sold in the old group buy that was organised by nate33t
- http://www.skylinesaustralia.com/forums/in...howtopic=107029
Minimum order: 10.
Cost: $60.00 including postage.
Starting Date: 22nd March, 2006.
Ending Date: 12th April, 2006.
(Please note that this will cost an additional few $$'s as nate33t had the company/business he worked for, pay for the postage).
Please PM me with your details and I'll add you to the following list of those who have requested/ordered one.
1. r33skyliner (myself) - PAYMENT RECEIVED.
2. Ol_Mate - PAYMENT RECEIVED.
3. R3LOAD - PAYMENT RECEIVED.
4. Syphon - PAYMENT RECEIVED.
5. LANFOH - PAYMENT RECEIVED.
6. Sweet_Gtst - PAYMENT RECEIVED.
7. WRXSUX - PAYMENT NOT RECEIVED, TAKEN OFF THE LIST.
8. writeoff - PAYMENT RECEIVED.
9. beastien - PAYMENT RECEIVED.
10. livicuru - PAYMENT RECEIVED.
11. khunjeng - PAYMENT RECEIVED.
12. Al - PAYMENT RECEIVED.
13. SLVR32GTR - PAYMENT RECEIVED.
14. code blue - PAYMENT RECEIVED.
15. reflexman - PAYMENT RECEIVED.
16. SLYLINER - PAYMENT RECEIVED.
17. mufro - PAYMENT NOT RECEIVED, TAKEN OFF THE LIST.
18. jonjon - PAYMENT RECEIVED.
UPDATE
There is no more orders being taken now. I've taken more orders then initially planned.
All PM's have been sent out with payment details. All payments are to be made by Friday, 14th of April.
https://www.sau.com.au/forums/topic/110619-genuine-nismo-leather-gear-knob-2/
  • Replies 161
I'm keen only if the gear knob has an inner plastic sleeve with a 10mm thread that can be removed.
The reason for this is that I still have a Nismo gear knob I bought from a previous group buy that needs the inner sleeve.
I figure I could swap the sleeve between the two and use the leather one in summer when the black chrome one is too hot to handle.
Those that have express their interest, your names have been added to the list.
Sorry, these nismo gear knobs will be the exact same ones as previously sold.
I just reread the previous Group buy on these gear knobs.
You have one in your car already right?
When you get a chance can you check if the inner sleeve can be removed.
The sleeve needs to be 55mm high, have an outer diametre of 20mm, and an inner thread of 10mm. If it matches these dimensions it should fit the other gear knob I have. Then I definately want one!
Thanks.
These are a great buy people. Currently going for between $90 - $130 on ebay, and that's BEFORE postage. They look and feel amazing in real life too.
Sweet_Gtst, you've been added.
Payment details will be provided once we have a full list.
To save myself time in the sake of not getting a full list, it would be best for everyone to make payment once I have a full list of people there. If I dont get a full list, then there would be no need to refund the money.
AD GIVEN TO ME -
NISMO LEATHER SHIFT KNOB!
**BRAND NEW AND IN ORIGINAL PACKAGING!**
Suits R32 R33 and R34 Skylines, but also other Nissans with 10mm shift, as far as i know, thats most of them! Please double check your vehicle prior to bidding
(300ZX and 350Z's have 15mm so will not fit on them)
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
