Hey guys,
I've got an R34 & have recently swapped the wheels from stock to some IB Racing 18"s - not sure what the style is called. As I have bugger all clearance (less than 1mm at the front, rear is fine), I'd like to know what's available to me to avoid scratching my rims (they don't rub but it's too close for comfort). Also, my studs really can't fit a spacer (I'm currently running around 1cm thick, but this is a temporary solution) so if I don't get a bolt-on adaptor then they will need replacement.
I'm keen to change the brake calipers if there is something available which is narrower than stock, or if it's more cost effective I'll be looking for some bolt-on adaptors. I'm located in Brisbane, so if you could provide any local contacts I'd be most appreciative.
Thanks
https://www.sau.com.au/forums/topic/110631-new-wheels-clear-brake-calipers-by/
I've got a good idea of what I need, I'm just after the most cost-effective way to do it. I have adequate spacers if I get longer studs, but at the moment I'm finding studs difficult to get in QLD. If anyone has any contacts, by all means share!
anyone who has R34 GTT rims on their 33 can testify that you wouldn't even get a piece of paper between the caliper and the rim... doesn't cause any problems though... as long as it isn't hitting... you can always grind a mm or two off the caliper?
None of you guys have Brisbane-based contacts? I appreciate the advice so far but if any of you have contact details it would be a great help
Dude, I just asked my mechanic to do it, and he got them put them in, gave me a torque wrench for the weekend to just keep and eye on them, and shes apples.
But having said that I have like 15mm spacers on, and still only have 2mm clearance if that. A gap is a gap :dry:
They are however still illegal, get the bolt on ones.
get rims in correct offset, or some form or spacer
Not having a go at you dude (cause I used to think the same way), but offset has little to do with brake clearance. Offset is more to do with suspension clearance. What is important when choosing wheels to fit over a large caliper is to look at where the spokes are in relation to the hub mounting.
Hi all,
Thanks for the input, but the real issue is that my wheel studs aren't long enough (barely half the nut is on the stud). Is there any other options apart from a bolt-on spacer or longer studs + spacers? I am happy with the size of my current spacers, so even if there is an alternative nut design (I've seen em on tractors, not sure about cars though - they have a sleeve, as I'll try to demonstrate. Please excuse the crappy drawings & attempt at 3D).
1. Normal Wheel nut
2. Design with a sleeve (to go inside the rim & give me some more contact area on the thread)
Does anyone know of anything like this available?
Edited by mrgilly
    • Definitely needs a hard top
    • Nah, shouldn't have made any difference. Reds on, or car running, should be same same for what you were doing.
    • Should be able to source 200 cell R32 cat... unsure how easy it would be to get it to Malta though.
    • Oh bugger ! Your right ! Good old hydrogen sulfide. Takes me back to the good old school days !
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
