Hey ppls,
Mate's car (coming ex-Japan) has an S-AFC installed. That's the version with the blue screen, six buttons.
The S-AFC II has the rotating knob instead of the buttons, and offers slightly more capability (more tuning points, knock reading, etc).
Without having a look-see at how it's wired up, is it possible to just unplug the S-AFC and replace it with a S-AFC II?? Or are the harnesses different in the newer one??
Thanks..
Ive never even looked at my knock sensor.
Here in SA the ecu add-ons are illegal, so mine are 'hidden' from view
"sorry occifer, I dont have a glovebox key, have no idea a SAFC2 & SITC are in there - wow sir dont those screens look p'rrity sir?"
maybe I can just shout out "I NEVER BROKE THE LAW - - - - I AM THE LAW"
and then crush his Trachea with my mind, Darth Vader style.
LOL
Edited by Tangles
Tell you mate to just stick with the SAFC, does the same job really. If the ecu is picking up knock it will retard timing. The knock sensor does give you something to look at when your sitting at the lights, watching it slowly creep, nowhere near dangerous however... but thats about all it does for me.
That is ofcourse if the warfies and sneaky boat people dont steal the safc outa the car on its way over from japan...
What I want to know is how accurate the SAFC knock reading actually is... I find that mine fluctuates with the weather (air temp)
Lowest I've seen after hour long drive = 0 ~ 15
Highest I've seen after hour long drive = 50 ~ 60
Obviously the air temps are very different on these two occasions.
From memory the plugs on the loom fopr the safc are physically different (the SAFC2 is wider) so if upgrading you will need to install it properly.
The SAFC2 only uses 1 wire for knock, the ECU's on RB's use 2 knock sensors hence 2 wires.
IMO it's already got an safc1 no point wasting the money an an safc 2 unless you REALLY want to see the knock reading (like me :))
as for accuracy, it varies from car to car because the baseline reading that you set in it (when you first calibrate them) would be different depending on the health of the engine.
All very good points.
In my opinion, I SERIOUSLY suggest do NOT buy a SAFCII, but do in fact BUY a Apexi Super Ignition Timing Computer (SITC).
Search ebay and pick one up, to compliment the tuning of the original SAFC. Worth every penny....
>_<
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
