Eastern Creek Half day Drive day THURSDAY 3rd April.
Ok,
Well here we go again.
Date: Thursday 3rd of April 2003
Time: 1 - 5pm (need to be at the track no later than 12:15pm to sign up)
Venue: Eastern Creek Raceway
Event: Track day organised through MOTO CONCEPTS
Cost: If we have more than 15 = $130 per car.
If we have less than 15 = $140 per car.
Event "Debriefing": To be conducted at the Cricketers Arms at the conclusion of the days track activity.
I'll be taking deposits ($50) again on this one and I was hoping that Dino or Brendanf might help out in this regard for the TNS people. I will speak to Silver to see if he could lend me a hand with TWS so as there are two people from each are to get deposits to.
Please post your interest here so we can get an idea of numbers.
Intrested people (deposits indicated in brackets):
Majanal
Roy ($50 24/2/03)
Silver-Arrowz
Merli
Duncan
Kel
Dazsta
Carlo
Tex
fatz
  • Replies 149
Bummer Brendan... I'll have to see about the deposits... might have to get them to dino if he is coming to this day.
Dino???
I'll probably be to the BK on cumberland cruise this saturday if people want to drop deposits... and I'll probably do the Nasho run on Sunday morning also.
Will confirm on Friday.
lol, the gauntlet is thrown down by the girl with the auto...
Dan, have you considered using the club account to take deposits, we could just put money straight in thru internet banking or through a branch, as long as we know who each deposit is from.
how can we get rocked by an auto r31 that is parked in the carpark with a blown turbo???
By the way... if anyone wants to pay a deposit tomorrow (Saturday) night... I'll be at Homebush 6c between 8 and 8:30pm.
Remember that if you don't have a deposit in then you won't get a guaranteed spot.
See you all there,
Dan.
I can't believe that would happen- Pete is such a sensible driver!
And you blokes should watch what you say about autos- my saabie has given a few skylines a run when she's been wound up :P
Kel
Ok, Date to be taking deposits, and final date to get them in, will be Saturday 22nd of March at Homebush 6c. I'll confirm time a bit closer to the day but it will probably be around lunchtime.
Can someone check and make sure that there is no cricket games on on that day please!!!
Cheers,
Dan.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
