Eastern Creek Half day Drive day THURSDAY 3rd April.
Guys, I'm officially out!
Blew too much money out at the GP and don't think I can afford a new set of rotors + a track day.
Also let it be known that Fatz is more than just nuts. He needs a psychologist and fast! That Mirage was crying out for him to stop punishing it!
  • Replies 149
You know pete.
Ok Date for deposits is definatly on Saturday the 22nd of March @ Homebush 6c. I'll be there from 11am to 12 midday. If I have to work then I have to leave at 12 sharp... if not I may organise a trip to the pub or a short cruise.
I belive that fatz is planning to be there for deposits for the skid pan day also.
Cheers,
Dan.
It would be so much easier to just give us a bank account to deposit money into, so we don't have to traipse all the way to homebush just for 5 mins...
Im in the same boat. I won't be in Sydney on that day anyway.
Intrested people (deposits indicated in brackets):
Majanal
Roy ($50 24/2/03)
Silver-Arrowz (scratching)
Merli ($50 dep 17/3/03)
Duncan ($50 dep 18/3/03)
Kel ($50 dep 18/3/03)
Dazsta
Carlo
Tex
fatz
scott d ($50 dep 18/3/03)
drifto ($50 dep with dino)
Kinks
Bonkers,
Are you going to come along to this one mate?
Ok Kinks... I've added your name to the list. Don't forget that to guarantee a spot you need to get a deposit to me by this Sunday. I'll be booking spots on Monday morning.
I'm out, unfortunately. Although the risk of anything happening is small I can't afford it if it does, and I'm not insured. I'll see my way to getting a cheap thrash car and then I'll take to the track with gusto :P
Kinks (and others),
I have been to many track days now... as have all the team trackday people, some of us just learn about our cars, some of go all out to try to beat our lap times, and some of us try to drift each and every corner.
Our cars are not insured while we are on track as I'm sure not many cars are. I know that these days organised by moto concepts have only had 6 or 7 accidents in there 4 years of operation, that is a lot better odds than driving on the road in my mind.
Provided you drive WITHIN your means then everything should be fine.
As I have said there are plenty of experienced trackies coming on the day that are always more than happy to take you out for a few laps and show you some lines etc. And I believe Bonkers is not driving due to the building of his new house, he might still come out to the track (can you confirm bonkers?) and he I'm sure will be more than happy to get out there in your passenger seat and show you where to go.
Even if you just come along for a watch this time to see what it is all about. I will be happy to take you out and show you what it is all about.
Dan.
Just to remind everybody,
Date: Thursday 3rd of April 2003
Time: 1 - 5pm (need to be at the track no later than 12:15pm to sign up)
Venue: Eastern Creek Raceway
Event: Track day organised through MOTO CONCEPTS
Cost: If we have more than 15 = $130 per car.
If we have less than 15 = $140 per car.
Deposits need to be payed before Sunday 23rd March 2003
Passnegers: $20 for unlimited rides (need to bring long gear and helmut)
Event "Debriefing": To be conducted at the Cricketers Arms at the conclusion of the days track activity.
Majanal
Roy ($50 24/2/03)
Dazsta
Carlo ($50 dep 19/3/03)
Tex
fatz
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
