Eastern Creek Half day Drive day THURSDAY 3rd April.
  • Replies 149
DIDO... as usual great day.
I thought the witches hats were a great idea, i normally tip in too early and wash out the front end on the exit or corners, i think it helped my line.
...and life begins with DJ-01s, speed limiter thru turn 1 !!!!!
Ok, I've got some pics from the day, I don't know all of you so I'm not familiar with whose car is whose in many cases. :D
Please also note that the track day was my first ever attempt at panning practice, and as you can see there's more practice to be had, so sorry if your car is blurry. :D I can only say I'll be at many more track days, so hopefully in the future these pics will come out consistently good. That said, some of these shots look pretty cool I reckon. Not a bad first effort. :(
Enjoy!
http://members.optushome.com.au/dal2/EC%20...20day%20gallery
Tex
Cheers to every one who went. I had a great day on the track for my first time its good to have had no incidents or failures with the car.
Thanks Roy, I enjoyed your 32 aswell. Next time you drive mine it might have breaks and I'll try and dial out the instability in the rear.
You can try a bit more boost next time!!!
If any one out there thinks their a quick driver and havn't been on a track, think again. And inject your balls with steroids too if you want to take turn one at more than 180k.
By any chance did some one pick up my ferrari hat at the Cricketers Arms. I think I left it there?????
Guys, was a top day... good to get back to the days where we had plenty of space in our group... just a shame that the nembies had to run with the oldies... shit... gotta think of a better way of putting that! They could have got more of an opportunity to get out with people that have been before rather than following them. I think following helped at least Carlo though... And it appears that we have a few more addictees!
Unfortunatly I was not as lucky as the rest of you... I managed to shear 3 bolts in my exhaust manifold and thus have a car that will be off the road now untill the 16th of April. Oh well could have been worse.
I'm looking forward to the next one... which will be on the Monday the 9th of June (that is ages away) however it is a public holiday... so no excuses!
:Owned:
Majanal said there was a shortcut over to turn 5...but I think he lied.
And I would have got away with it if it wasn't for the paparazzi on the hill there.....the price of fame.....
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
