OK guys i need some help spending my money. ive got a stock as r33 gts t s1 and i got about $5000 to spend. im looking for an all rond package of goodies ie: wheels, suspension, engine. with a hopeful power output of around 200kw. any suggestions on what and where to get things would be very appreciated.
thanks heaps and happy shopping ;)
https://www.sau.com.au/forums/topic/110653-shopping-list/
Full exhaust, including spilt dump pipe n cat.. -- cam gear exhaust side
Front mount and new pod with sheild
power fc and tune, with boost controller n puttin more boost
that should make 200..
then if u got money left over, you can think about suspension n new wheels.. hehe.. hope that helps in a way!!
but if it was me, i would be doin it in steps over months.. so you appriecate the car more.
Edited by siddr20
https://www.sau.com.au/forums/topic/110653-shopping-list/#findComment-2038634
(estimates)
Wheels + tyres = $2000
Suspension = $1000
200rwkw worth of mods =
Turbo-back exhaust = $1200
Panel Filter = $100
FMIC = $1000
Boost Controller = $200
Exhaust Cam Gear = $250
Power FC + Tune = $1500
Fuel Pump = $400
= $7,650
..and i'm sure their are a couple of things I have missed.
https://www.sau.com.au/forums/topic/110653-shopping-list/#findComment-2038682
I think you guys are all forgeting the most important,
Fluffy Dice= $2.50
If you are after a Power FC log onto www.nengun.com
By far the cheapest price anywhere for fc's. Unless a group buy is going around of course.
https://www.sau.com.au/forums/topic/110653-shopping-list/#findComment-2039103
Just to give you an example, here are the mods that I had when I was making 194rwkw (car was originally stock)...
Blitz LM FMIC: $1500
Power FC: $1000
Profec B Spec II EBC: $500
Turbo-back exhaust (w/hi flow cat converter) $1100
K&N Panel Filter: $100
Heavy Duty Clutch: $1100
Total: $5300
Obviously you could probably save some cash on the FMIC by buying a Hybrid or Just Jap jobbie...most people seem to think they do a reasonable job.
Hope that helps.
https://www.sau.com.au/forums/topic/110653-shopping-list/#findComment-2039551
Power fc - $950 delivered - See here
Hybrid GT spec front mount kits - $630 delivered - See here
suspension - See here
front and dump pipe - See here
High flow cat and cat back system - PM me for more info.
Air filters - PM me for more info.
boost controller - PM me for more info.
These parts will give you around 200rwkw and you should be able to get it all for under 5K.
After this you probably should consider upgrading your fuel pump and coil packs.
You may have to gather more funds for some wheels though....See here for some good packages.
:P
https://www.sau.com.au/forums/topic/110653-shopping-list/#findComment-2044150
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
