just thought you guys might like some fun reading. this guy has spent a shitload of money on rebuilding his motor and got 145kw out of it on 11psi and is hoping for 200+. im a member of preludesaustralia as i used to drive a 3rd generation prelude before my skyline.
but yeah.. have fun
http://www.preludeaustralia.com/forums/ind...showtopic=13657
https://www.sau.com.au/forums/topic/110655-some-guy-rebuilt-and-turbod-a-honda/
try the new link..
well a guy from there has rebuild his motor with forgies and billet rods. around 1yr later and hes pulling 145kw on 11psi and thinks its a monster, so does the rest of the forum.
i dont think anyone would want to be a member of prelude australia :P
how much would he have had to spend to get 145kw from a honda, considering he went with forgies n that. and his running 11psi too lol
Well the answer is always gonna be -- For the cred
People often spend shitloads on slower cars so that they have something 'different'. It's common sense, that if you want a faster car, you start with a faster platform.
This guy obviously wanted a prelude specifically, that goes faster than most others :P
It must have taken him sh*tloads of heart-ache to get where he is, he probably deserves a bit of credit, even if it isnt a tyre frying monster! .... well, it probably IS a front tyre frying monster, but you get what i mean! :D
Edited by Primordial
power to the bloke for doing something original.. but he would've gotten more out of putting an type r motor into his car and starting from there.
the only reason i did this was to give him a taste of his own medicine.. he put a poll up at once stage asking how UGLY another members car is.
WTF - I didn't bother signing up, but he's clearly doing something seriously wrong. One of my mates have a forged H22A and large turbo on his Prelude and did a run on 6psi (only tuned for engine run in) and managed a very wheelspinny 13.2 @ 186kph. With 11psi and a built motor (built motor is an advantage as on NA the tune is usually just to keep it alive) an H22A should be making some pretty decent power.
They are at least comparable to an RB25DE in NA form, so the same would suit for when a turbo is attached to a built RB25DET.
I think some people just have too much money on their hand or they just want to be different (credit to them for their creativity though) .Turbo charging a H22a can give you a pretty quick car if done properly, there are endless examples in the states due to cheap parts. But like the other says you will need to have a pretty deep wallet and comes with plenty of heartaches as well along the way. A stock 5th gen vtir is pretty quick for a na car (cause I have one) and I can tell you it beats a stock na 33 easy.
Haha my bad havent read the topic in PA just going on what the previous post said. The 89 ludes are very light plus turbo should be pretty quick on the quater.
My bad - sorry for putting you wrong on that :P
I had assumed that the only Prelude that anyone would bother turbo'ing would be one with an H22A in it. B20As are pretty poos.
I've got a couple of mates with stock engine'd Hondas (one a 1.8VTEC Integra, the other a 1.6VTEC Civic) both running 8.7psi (.6bar is a nice safeish boost level for a stock VTEC motor) and both do mid/low 13s quite happily and reliably.
Most cars beat NA R33s...then again Nissan relies on turbos for performance cars.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
    • Oh nah, S55 doesn't eat bearings, just the crank hub slips lol.
    • When’s the tow ball on the 33 coming? 🙃
    • I welcome any basic question that can help haha. Yes it has 2 unis but the driveshaft is a one piece and the unis are welded without a slip yoke at each end.   What's funny is anytime I've ever had wheel vibrations it's always been in the front so I automatically assume it will lead to steering wheel shake and not chassis vibration. With that being said, I never considered looking at my rear wheel balance... I have doubts though as this wasn't an issue before I pulled the motor and trans but is still very much worth a look. I'll do that tonight after work. Thanks.
