I just wanted to post this dyno sheet to show what sort of difference a GOOD tune can do for car with a PowerFC.
The only difference between the two runs was a minor service, and the PowerFC Tune (done by Ben @ UAS). He did an awesome job as you can see! ;)
Free plug for Unique AutoSports! They did a great job!
https://www.sau.com.au/forums/topic/110666-power-fc-tune-unique-autosports/
  • Replies 44
Yeah definitely. It's a very noticable difference!
A lot better response now. The turbo that is in there (Apexi unit) spools really quickly now, whereas before it was really sluggish to get going. It's a lot more fun to drive, as I found dont have to concentrate as hard on keeping the revs up in certain corners etc.
But you said it - I'm happy with it "for now"... Give me 6 months and I'll want more. It's the relentless pursuit for more power we all suffer from! :P
Lol not me.. I just want to win an auction on a damn 33.. then my licence back.. May 23 and were rolling! Im on here to pick up a few tips/tricks before i get it.
224.7kw that would be nice and lively in the hills i bet.. what other mods do you have? 2 Way LSD? Coils?
Yeah there isnt that many places to really open the car up in the hills (best left for the track anyway!!)
Are you buying privately, or through an importer?
Other Mods:
Apexi GT Spec FMIC
Apexi Turbo (380hp)
Apexi PowerFC
Apexi Boost Control Solenoid
Apexi N1 Coil-overs
3" Exhaust (Turbo Back)
High flow Cat
Bigger injectors (550cc or 700cc, not sure)
Aftermarket Fuel Pump
Standard Coils (For now...)
etc.. etc.. etc..
thats some nasty AFR's on the initial runs.. how long you been running on that tune for?
did ben do much work with the around town/light load maps?
how much did it set you back to tune? and how long?
I'm not sure of the exact amount, as I got a bunch of other maintenance type stuff done as well.
Approx $450-500 I think. Ben did mention it was a full tune from scratch because there was some silly stuff in the old tune (originally from Japan). Total time on the dyno was about 4.5 hours i think.
I had been running that tune for about 4-5 months..
lol.. yeah just about...
I would wash my car, and within a week, there was black stuff all over the bumper again... it was very annoying!
suprisingly i didnt get THAT bad fuel economy... about 15.5L/100k.. But it should be miles better now!
Yeah as i mentioned above, black crap all over the rear bar was a regular occurance.
Surprisingly i've noticed more black smoke since the afr's have been fixed. Either that, or i've just got more time to look at the guy in the rear view mirror since gaining the 30rwkw :P
Yeah it does add up, but i'd kill to have a 225kw turbo that does 10.5l/100k!! BTW Craved, where do you live? :P
:D
im from out near richmond (NSW) but yeah driving from out there to pennant hills is a pretty ok drive for fuel savings..
let us know what fuel economy you get, am keen to see
Yep, ill let you know.
Ahh yeah thats a decent distance! I live right near Pennant Hills actually.
Small world, or over population of skyline owners? :P
Nah that wasnt me, but there are a couple of others in the area.. If it had a black bonnet it was Wilch.. There is also a guy that lives around here that privately imports and sells skylines, so it could have been one of his.
I'm surprised I havent seen you around anywhere though.. do you usually have the skyline around this area?
used to drive it around, but its pretty much been off the road for the last year haha
it was only the wing that made me think of you.. and yeah i know wil pretty well, it was past his house anyway lol
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
