Yeah there isnt that many places to really open the car up in the hills (best left for the track anyway!!)
Are you buying privately, or through an importer?
Other Mods:
Apexi GT Spec FMIC
Apexi Turbo (380hp)
Apexi PowerFC
Apexi Boost Control Solenoid
Apexi N1 Coil-overs
3" Exhaust (Turbo Back)
High flow Cat
Bigger injectors (550cc or 700cc, not sure)
Aftermarket Fuel Pump
Standard Coils (For now...)
etc.. etc.. etc..
Through an importer mate.. Here in SA. Keep missing out on 33's now.. after initally wanting a Type X 180sx.
Oh well keep bidding and ill find one i guess.. Pretty much everything on your mod list i want.. bar the n1 coils.. i think ill go TEINS, maybe SARD 550ci injectors and hybrid FMIC/GTR even.
  • Replies 44
Sweet.. Well you'd probably have more luck finding a 33 than a 180sx. There is millions around now... Have you thought about buying through a Melb or Syd importer and shipping the car to you? You may save a bit of money, and they would also have more eyes at the auctions to find the car thats right for you.. Just a thought.
Cheers bud.
Im loyal to my importer as he is a friend of a friend..
Im really not that fussed about the $$ So long as i pick up an extremely clean example.
Trouble with type x's are they r rare as because they only came out 96-98 with the kits.
Still sellin for a dime in japan!
  • 4 weeks later...
Wow - under 10:1 AFR..
Did you notice black smoke coming out the back or any black marks on the rear bumper?
Well guess what. I had my car at the tuner shop for 3 f**king hours. He charged me $300 (plus the other 2 1 hour tunes he "performed" recently before that)
and the f**kwit came up with this result.
NOw the car has a GT30, 500cc Injectors, powerfc and datalogit, exhaust and fmic, etc etc. Should be making 260rwkw.
See the dip in that torque curve? Hooking up my mates AFR revealed that it was running at 9:1 at that point.
And this tuner is supposed to be good? My f**ken ass.
tune it yourself. it cant be that hard. sydneykid has explained it before so do a search on his username for "dyno" or something and you should find it, was about 9 months ago. or road trip to melb and get it sorted :)
eww... that bites man! tell him to give your money back and go elsewhere. I know you might not have too much choice in your area, but screw getting charged that much for a shitty tune :)
Cheers bud.
hey man is ur importer in ADEL Kristan?? i am importing a R33 GTS-T 98 model landed for just under $16,500 its stock, clean and straight bargain, he can get 180's and all sorts of imports, if ur interested pm me and ill give you his contact details!!
Oh ok.. a worthwhile upgrade by the sound of it. A skyline would still be better :)
Primordial.....WTF, i have to say something ....your af ratio's are... well lets just say that " AM I THE ONLY ONE WHO SEE's THIS" the a/f ratio's are SHIT HOUSE I WOULD GO BACK AND COMPLAIN OR ASK FOR MY MONEY BACK>>>>?........
sorry no offence but it had to be said....
dude, his af's are near perfect. around 11.8:1, probably just on the safe side of things, which is what you want. i would be extremely happy with a tune, power curve, price of tune like that on my car.
His AFR's are fine.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
