Hi,
I'm looking at installing a few gauges (already have aftermarket boost).
Which guages do think are essential for monitoring; considering I'd like to do some trackwork down the line?
Are there any factory gauges that I should really consider replacing?
Thanks for any info...
The only necessary one is "Oil Temp" (for track work that is)
https://www.sau.com.au/forums/topic/110671-gtr-gauges/#findComment-2039367
actually i would say oil pressure is equally important to oil temp in an RB26 (and any engine really), if not more so.
i would get:
oil temp, oil pressure, boost pressure. you can use the stock volt gauge, it's close enough and if you have a PFC use the hand controller to monitor water temp, if not grab one a water temp gauge too.
appart from that the only nice one to have would be an EGT gauge but you need to know how to read it to get any value from it.
https://www.sau.com.au/forums/topic/110671-gtr-gauges/#findComment-2039397
Ɨ
Ɨ
