Cubes Posted May 26, 2006 Share Posted May 26, 2006 What did you end up doing for lifters? I now have a spare s/h set here, will pull them out and give them a good clean. Also.. Can you take note if there's ANY difference in before/after oil pressure. Obviously only when warm, allthough it may also affect cold but my guage max's out on cold start up anyway. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2203329 Share on other sites More sharing options...
GTRgeoff Posted May 26, 2006 Share Posted May 26, 2006 To clarify the table I've reformatted in Excel and produced as PDF with appropriate credits to SK. RB_oil_gallery_mods.pdf or download here oil mods Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2203374 Share on other sites More sharing options...
Guilt-Toy Posted May 26, 2006 Share Posted May 26, 2006 (edited) Cubes I ended up scoring a second hand head at a decent price so I am taxing the head for the lifters - cheapest option is to use standard second hand ones for now as im not changing the cams to go for solids. My engine max's out on oil pressure when cold too. So yeah when i get it all running again I will post the oil pressure results. The biggest thing for me will be the amount of oil being pushed out of the engine - get tooo much oil in the top end. Going to be a big mission. What did you end up doing for lifters?I now have a spare s/h set here, will pull them out and give them a good clean. Also.. Can you take note if there's ANY difference in before/after oil pressure. Obviously only when warm, allthough it may also affect cold but my guage max's out on cold start up anyway. Edited May 26, 2006 by Guilt-Toy Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2203436 Share on other sites More sharing options...
SirRacer Posted May 26, 2006 Share Posted May 26, 2006 thanks very much for that sydneykid, top information indeed does anyone want any specific pictures of an engine being assembled as mines off to the machiner and then will be assenbled in a few weeks time Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2203497 Share on other sites More sharing options...
R33fourdoor Posted May 26, 2006 Share Posted May 26, 2006 Howdy SK, Mate, you really need to fire up Excel one day....you don't know what you're missing out on!! As the formatting was all cocked up on your original post, I decided to pop it all in a nice, neat Excel table for you. Just have a quick double check to make sure all of the values I entered are correct. Hope this is useful (god knows, what you do for us sure is!). Cheers, Mike Nissan_RB_Cylinder_Head_Oil_Restrictor_Chart.zip Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2203508 Share on other sites More sharing options...
R33fourdoor Posted May 26, 2006 Share Posted May 26, 2006 Haha....looks like everyone was thinking the same thing!! Cheers Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2203516 Share on other sites More sharing options...
GTRgeoff Posted May 26, 2006 Share Posted May 26, 2006 And I'm having trouble downloading so I hosted it on my website as well Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2203542 Share on other sites More sharing options...
Guilt-Toy Posted May 26, 2006 Share Posted May 26, 2006 Hahahaa looks like everyone is jumping at the opportunity to help Sydney kid - Seeing he helps us out all the time =) Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2203614 Share on other sites More sharing options...
carl h Posted May 26, 2006 Share Posted May 26, 2006 my only worry is blocking off the rear restictor on my rb20 eventho im using a n1 pump. i can see using a 1.5mm restrictor in the front but wouldnt it be better to run another 1.5mm restrictor in the rear feed. im just trying to understand the how and why behind this as my motor isnt as worked as sk stated it should be in that chart... Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2203821 Share on other sites More sharing options...
Guilt-Toy Posted May 26, 2006 Share Posted May 26, 2006 my only worry is blocking off the rear restictor on my rb20 eventho im using a n1 pump.i can see using a 1.5mm restrictor in the front but wouldnt it be better to run another 1.5mm restrictor in the rear feed. im just trying to understand the how and why behind this as my motor isnt as worked as sk stated it should be in that chart... What i noticed with Sydneykids posts is that when he says something he is allways right wether its a generalisation or not. (if that makes any sense) Note the Topic. it says. "Oil Controll In Rb's" RB means rb20 as well to me! Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2203914 Share on other sites More sharing options...
benm Posted May 26, 2006 Share Posted May 26, 2006 Hahahaa looks like everyone is jumping at the opportunity to help Sydney kid - Seeing he helps us out all the time =) If everyone whom he helped sent SK only 1 carton of beer he'd put VB out of business. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2203964 Share on other sites More sharing options...
Guilt-Toy Posted May 26, 2006 Share Posted May 26, 2006 If everyone whom he helped sent SK only 1 carton of beer he'd put VB out of business. Supply on demand is why fuel costs so much. So if everyone did this.. Imagine how much a carton of beer would cost ? lol Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2203979 Share on other sites More sharing options...
Guest Mashrock Posted May 26, 2006 Share Posted May 26, 2006 what do you do when your car has come from japan, clearly has been used for circuit work, and looking like its raced many laps and still goes like a champion? should i suspect all the parts are inplace? as auction sheet tell me sheet all. i do have rather large oil pressure. compression is fine and everything else is a1. caus i'm stingin to take it out to eastern creek for a good ol thrashing. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2204253 Share on other sites More sharing options...
bnr#@ Posted May 26, 2006 Share Posted May 26, 2006 None of the links to either the excel or the pdf file work for me... Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2204368 Share on other sites More sharing options...
Sydneykid Posted May 26, 2006 Author Share Posted May 26, 2006 what do you do when your car has come from japan, clearly has been used for circuit work, and looking like its raced many laps and still goes like a champion?should i suspect all the parts are inplace? as auction sheet tell me sheet all. i do have rather large oil pressure. compression is fine and everything else is a1. caus i'm stingin to take it out to eastern creek for a good ol thrashing. Take a look at the sump, if it has wings then it will most likely be OK. If it doesn’t have wings, then I wouldn’t be going anywhere near a circuit until it does. Especially if it’s a 4wd. Just because it lived a life in Japan, doesn’t mean it will live one here. The guy driving it might have been a woos and blasted down the straights and trickled around the corners ie; no G forces to cause the oil surge. At the very least watch the oil pressure and temperature guages like a hawk the first time out. Cheers Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2204378 Share on other sites More sharing options...
SirRacer Posted May 26, 2006 Share Posted May 26, 2006 (edited) while we're on this topic, what is the best way to block the other oil feed? so we block it at the top? are there any issues with oil riding in the block however not circulating? Edited May 26, 2006 by SirRacer Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2205897 Share on other sites More sharing options...
Guilt-Toy Posted May 27, 2006 Share Posted May 27, 2006 while we're on this topic, what is the best way to block the other oil feed?so we block it at the top? are there any issues with oil riding in the block however not circulating? I was just going to block it of with some newspaper or some glue tak or something LOL j/k Hmmmm.. Good question... Whats the best way ? can just tap the old restrictor down and screw something in its place to block it off? Hmmm Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2206256 Share on other sites More sharing options...
Turbine Posted May 28, 2006 Share Posted May 28, 2006 Yes I'm interested in how other people have blocked off their oil flow restrictors to the cylinder head as well. What is the best way to do it? Turbine Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2208470 Share on other sites More sharing options...
Craved Posted May 28, 2006 Share Posted May 28, 2006 you could use copper rod at the diameter of the feed, after you knock down the original restrictor .. pretty sure this has been suggested as an alternate to the purchase of a tomei style restrictor when you can use copper rod with a hole drilled to custom specs .. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2208838 Share on other sites More sharing options...
Turbine Posted May 29, 2006 Share Posted May 29, 2006 So once you have knocked the origanal restrictor down. Where does it go?? Does it stay in the block?? Not sure I like that idea, maybe you can use an ease-out to pull it clear of the block??? As for a new size restrictor, just make up a bronze or copper bush with the right size orifice! Sounds too easy. I'll check this out this week and get back later. Turbine Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/3/#findComment-2211134 Share on other sites More sharing options...
