did you fit a crank collar to your rb30 bottom end, iirc the rb30 has the same short snout issues with the oil pump drive as the early rb26...
might have caused pump failure.
I am pretty sure my oil pump has been screwed for the last 6 months causing me these issues. Getting a GTR pump and hopefully installing it this weekend.
we get the same lifter noise occassionally when the revs drop right down to a crazy low rpm, like 600 or less. But it clears when oil pressure returns to normal. So a lack of pressure will cause the lifters to tick abit. There might have been no problem with them originally, as in not bad enough to replace but its infact your oil pump that needs seeing to.
Yes i think its pretty much a deadset certainty that you need the collar to avoid the oil pump cracking issue.
Edited by r33_racer
pulled down the engine and found that every piston had all the rings broken and in pieces except for one piston. Most of the bearings were scored and number 6 had spun and welded itself to the rod.
So its rebuild time. not going to bother with stock bottom ends anymore. waste of time
Guilt Toy..
Any idea why the bottom end had such a catastrophic failure?
There must be a reason, not just because it was a stock bottom end.
If number 6 had spun... Usually that's a sign of rod bolt stretch from my understanding?
What rings are you going to look at this time around? King have a good rep with the rb30's. However its a must they run the HP bimetal bearings as trimetals are crap in a performance application.
Apparently my style of driving is enough to kill any engine. I like to hit the rev limiter and i like to hit it hard. I like to boost the engine hard on weekends.
Its got 350rwhp... so the stock bottom end was no up to the task ?? I am being forced to upgrade to forgies so this does not happen in the future but i dont know why i need forgies... stock should be enough but in this case it could not handle my style of driving
forgot to mention that i do 140ks a day in the car to drive to work and back and I aint shy on kickin people's ass
The car went hard even though it had the noise.. what cracks me up is that it went that good with a totally screwed engine.. so thumbs up all round - guess i gotta look on the bright side of the situation and build a tough engine this time.
Guilt Toy..
Edited by Guilt-Toy
A lot of the rb30 blokes are running precision hypereutectic pistons with either nissan or king bearings, some run acl.
Apparently the acll hypereutectic pistons are shiet. :laugh:
There's a bloke here on sau s3girl, he's been pushing 373rwkw through his rb30 running std bearings, bolts and hypereutectic pistons with a GT40 bolted on the side for quite some time, I believe rev cut is around 7k.
make one yourself!
where can i buy a 1 mm restricter? why don't all the big brands sell restricters that size. how much bigger should i drill out the oil drainn holes in the block and head?
Sorry for the bad news Guilt Toy :laugh: . Keep in mind that a failed oil pump will kill any engine even if it has forgies and good rods/bearings etc. My 25/30 vct engine has no restrictors but one oil feed blocked off. It had a set of new(apprently) lifters put in during the build but it tics quite loudly on one cyclinder ( I think only one) for a few seconds after start up..... I suppose I will have to try changing the lifters first but its super pricey for new ones and using s/h ones could be dodgy and doubling the job if they are stuffed too! In the past for me , s/h lifters have manage to suck in gunk when transferred from one head to another. As they fully extend with no load when you take them out, mine seem to have become clogged and you can't clean them!!
Good luck! :)
i agree, and i dont think an oil pressure problem caused piston ring failure either, sounds like severe detonation.
If your spinning bearings, I don't think you need forged rods and pistons.
I did not give this engine a easy time. Its time to upgrade.. New engine specs will be
Aries Forgies
Spool Rods
Crank collar fitter to stock RB26 pump
fully balanced bottom end
Possible valve spring upgrade (does anyone know how much the stock rb25det head valve springs can handle before they start floating?)
Might push the power to 450rwhp then and more for dyno sheetoff's
Aries Forgies
Spool Rods
For the price of the spool rods its pretty hard to say no. :D
I was talking to one bloke a little while back via PM that began experiencing float at 20psi through is r33 rb25det head. I believe he may of went with a set of springs from PerformanceSprings. ~$285 for a set.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
