Oil Control In Rb's For Circuit Drag Or Drift
Thanks guys for the help.... Can't wait to get this done to mine....Because my motor is out for Top end build and re-assembly and i might as well do that and the restrictor while its out.....This is a good as thread. lol. Thank god for the Aussie's.
  • 3 weeks later...
So would there be any issue welding the plug below the oil level for the external oil return?
I bought the rear drain kit from Dane at Densynz and he instructed to weld the plug below oil level because high crankcase pressure would cause the oil to stall inside the line..
There are two takes and i'm confused which one is the more functional route..
So who's blocked off the rear oil feed of their RB20 or R32 RB25DE non-vct head? (i.e only one restrictor feeding the head)
I've tried to see if the two feeds within the head are joined and be buggered if I can feel any vac through the rear feed. :S
Maybe its the way I'm testing it. I've blocked off everything there is to block and there is a good deal of vac on the one oil feed yet the other see's nothing. :D
I believe you can probably run it above the oil level so long as its on the exhaust side i think(could be inlet, have to check with someone who knows exactly) so the crank vacuum helps pull the oil out of the return. I would think exhaust side, as the factory scraper breaks the vacuum from the inlet side so it also being the low point of the sump would be coping all the oil and broken windage. Need gary to cross check my thinkings, he would know for shizzle.
  • 4 weeks later...
I've been putting it off for a very long time.
Finally bit the bullet put faith in SK, closed my eyes blocked off the rear, 1.5mm up front and there appears to still be plenty of oil flicking around in the cam covers. I'll put a few hundred kays on it and check it out but I'm certian it will be all good.
R32 RB25DE head.
I think an Apology is in order for Gary (Sydneykid).
I doubted his suggestion that a 1.5mm restrictor up front and rear blocked off was perfecty fine for the R32 RB25DE head with no VCT.
So I went and did it anyway :thumbsup: and it is 100% percent fine.
Plenty of oil up top; top ends nice and quiet; no tapping when it comes off a rev; its all good.
So my apologies Buddy!
I've checked catch cans and there's absolutely no blowby; completely dry.
Yours doesn't count as you have an additional feed via the VCT to the head. :P
My problem was I didn't know of any one with an Rb20DET or R32 Rb25DE non vct head that had run with 1 restrictor blocked and a 1.5mm up front. The R32 Rb25DE and Rb20 heads are near identical apart from slightly larger ports and the larger combustion chamber/valves etc. So I wasn't completely comfortable using the R33+ Rb25 VCT head as a comparison that it really did work without problems. :yes:
But yes.. Still more than enough oil floating around; I've noticed I can now see the top of the bucket where as prior oil was constantly filled 1/4 up the base of the cam so impossible to see the top of the bucket.
can anyone confirm with 100% certainty whether the oil drain from the rear of the head is on the LSH (ex side) or RHS (in side)
seen all the pics and read everypage, and have come across conflicting info.
SET IT STRAIGHT
one thing i dont get is.. all the machining etc etc. lining up the gasket etc.. just how much oil do you think will have to "build up" to flow down the standard oil drains. all 18 of them. i rekon mayby 2-300ml at most..
i mean its all a good idea but is it really that efective? has anyone done any tests to back this up? like on a circuit car with the standard sump with and without the drain?
or is blowby the issue here, where it all blows up the oil returns slowing the return of oil back to the sump?
oil drain is on both sides of the head/block
i think i may have worded that question in correctly. when the oil drain is ran from the back of the head do you put it on the left side or right side of the sump???
Dave, watching the amount of fumes/smoke exiting the catch can vent at high rpm on the dyno I'd suggest there is some resistance to the head return flow but not massive. Still not entirely convinced a return is necessary but if you are considering fitting one then at build is the only time that is sensible.
hans, it doesn't really matter but most go left as that is the natural lean of the engine and run it into the sump.
we tapped the left of the head and run it aroudn the back to the right of the sump in front of the diff - just enough room to fit it, although the fitting in the head will foul the standard boost lines that run around the bacl
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
