NP mate. it does not require welding but it will require your machineist to machine down the crank and fit it correctly. its not a easy job and you have to have the crank out of the engine to do the task.
what was the other question? did you read through this thread ? it has everything you need.
always balance everything that goes up and down and round and round. Might as clean up the crank too while there, any dags and casting marks clean it up and get it slippery smooth.
In regards to the RB25 , why is the front feed blocked off and the rear feed restricted but with the other engines its the rear feed that gets blocked off and the front feed get's the restrictor as per sydneykids table ??
we dont know where sydney kid comes up with his ideas but they have been proven to work time after time after time so its a good idea not to ask questions how he comes up with it...
I think it may be because the rb25 has hydro lifters and its required to have it setup that way to run them properly where the gtr has solids which does not need the same kind of oil configuration.
Mine is done as per Sydney kids instructions and its been running for 2 years and 363rwkw.
There are many others whos are running well too. I dont know why people have to question it all the time.
well i certainly do not know thats why i am asking these question's b4 i put the motor together .. i want to be 100% sure all is correct ..
in saying that guilt-toy if you install the non vct 25 head you block of the rear and feed the front but with the 25 vct head its opposite and both have hydraulic lifters..
thats is correct??
I run the non-vct RB25 head.
I blocked off the rear restrictor as the Rb26's are and run a 1.5mm restrictor up font.
Works fine no ticks, pops etc. Went from shit loads of oil everywhere over 5500rpm+ to a bone dry catch can. Still plenty of oil floating around in the cam covers. Prior on idle oil was puddled up to the base of the cam so you couldn't see the lifter. Now u can.
As a few have experienced; if you experience hydraulic lifter tick once the motor is warm its a tell tale sign the motors on its last legs. Recently happened to a mate of mine running an rb30det.
what went on your mates engine when it went ? i get lifter tick for about 5 seconds when i start the engine on cold startup only...
just wondering what went on your mates engine
Lifter tick when the oil was warm and poor oil pressure no bottom end knocks or noises. The lifters were silent when cold.
Mine is fairly decent on cold start up, I only get an occasional tick. I can't remember the last time it ticked but I haven't been driving the car during the week for a while.
The RB20 was the same. Occasional tick.
Yeah well i checked my oil change sticker and it has been 6000km's since a oil change!! so thats why they would be ticking.. oil is getting a little old but its 300v chrono which is known to last longer then normal fully synthetic oil.
will change it in the next week or 2 :) ooooopppss
thats a pretty over the top solution Beyond Horizon, you will never fit the standard piping back on if you go a fitting like that. A simple 90o angle with 1/2 hose barbs on one side and 3/8 BSP thread on the other can be tapped into the head just to the right of the fitting in that pic - much easier, smaller and about $3 for the fitting
But will it flow as well, bearing in mind we are talking gravity feed here?
Do you know where i can find some pictures of this modification you're talking about or do you have some ?
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
